installed aftermarket intake kit now engine dies
Old Apr 16, 2009 | 09:20 AM
fishkiller72's Avatar
last night I installed an aftermarket intake kit on my 94 4runner with a 3.0. it is a k&n filter that attaches to the MAF and a tube that connects the MAF to the intake junction. when I had the intake off I cleaned inside the throttle body w/carb cleaner. it runs fine however when I let off the throttle the tach goes instantly to zero and the check eng. light flashes. the eng is still running. the idle seems high when I first start it. I think it could be the throttle pos. sensor or maybe I tweeked something in the MAF when changing the tubes any ideas?
Old Apr 16, 2009 | 09:47 AM
anthony1's Avatar
There's a connector that goes to the MAF. Make sure that is secure and free of dirt.
Sounds to me like there's no signal telling the computer how much air comes in.
Old Apr 16, 2009 | 09:53 AM
abecedarian's Avatar
possibly the connector to the AFM, or maybe one of those to the igniter got bumped, but it sounds more like the intake isn't sealing well between the throttle body and AFM
Old Apr 16, 2009 | 10:30 AM
xzyragon's Avatar
plug the afm in
Old Apr 17, 2009 | 05:06 AM
everlastingz289's Avatar
Make sure the intake is well connected/sealed, I had the same problem when mine fell off, too much air dont work.
Old Apr 20, 2009 | 11:36 AM
update
thanks to everyone for the advice. turns out I inadvertantly damaged the connector at the MAF when I unplugged it. that sucked! cost me $225.00 for a rebuilt one. installed it and no more problems. the only thing is that it seems to idle high(1000 rpm) after it warms up.eventually it goes down to around 700-800 rpm. it just seems to take awhile to come down. I don't know it has anything to do with the intake or not. any thoughts would be appreciated.
Old Apr 22, 2009 | 12:19 PM
toyotarunner92's Avatar
mine does that too. i have a cold air intake. just the way it works i guess. but i also live in phoenix where it is currently 103 degrees.............. ugh already... mine has done that just as long as it does go down you should be fine.
Old Apr 22, 2009 | 12:25 PM
Matt16's Avatar
What they said, check the AFM connection.
Kiroshu's Avatar
i know that those after market cold air intakes suck on cold mornings....
sonic concepts
Aug 16, 2025 03:13 PM
voiddweller
19
May 2, 2016 09:10 PM
91toybeater
Dec 27, 2015 07:46 PM
puffin04
Jul 10, 2015 09:17 PM
Yoda
Jun 23, 2002 09:39 AM
