Just replaced both CV axles but that clicking sound is still there!!
Old Apr 18, 2009 | 02:28 PM
skestral's Avatar
Hi everyone!
I just replaced my CV axles and I'm still getting an aweful clicking/grinding sound when I turn hard right, but only hard right.
I have a 1990 4runner, v6 4wd, 3vze engine...
What did I do wrong? I bought both the axles new from Autozone.. =\
Old Apr 18, 2009 | 02:30 PM
mattaway's Avatar
how are your tie rod ends? how about the balljoints? they might be grease starved and making noise when you turn and the weight of the vehicle shifts
Old Apr 18, 2009 | 03:06 PM
skestral's Avatar
I haven't actually checked those things... I'd have to take the joints off to properly grease them, wouldn't I?
Old Apr 18, 2009 | 03:15 PM
mattaway's Avatar
on my uppers i noticed a little bolt on the top where a grease fitting my be able to be screwed in, i just have't messed with it though.
i haven't noticed anthing like that on the lowers.
but it's basically too late when they make noise. you can try it, but i think you'd be better off replacing the parts.
Old Apr 18, 2009 | 03:17 PM
iamsuperbleeder's Avatar
most lower have a grease fitting facing directly inwards towards the center of the truck; you'd have to crank the wheel to full lock usually to get a grease-gun on it, at least I had to
but not all with have them; my replacements did though
and true about the making noise and it being too late. it's like U-joints... once they start making noise, the damage has been done, and you need to consider replacing them very soon before they do more than make a little noise... at least when a U-joint fails you just coast to a stop normally... if a ball-joint fails... well... it's not going to be pretty
Old Apr 18, 2009 | 03:19 PM
gary96360's Avatar
sway bar bushing? my truck made a nice noise turning right when i turned onto a street ect. i inspected the sway bar and saw there was no trace left of the bushings so i decided to take it out. broke a endlink and couple of bolts so i chucked the sway bar. the sound is gone
Old Apr 18, 2009 | 03:27 PM
good tip Gary
Old Apr 18, 2009 | 06:40 PM
gary96360's Avatar
Originally Posted by iamsuperbleeder
good tip Gary
why thank you
Old Apr 18, 2009 | 10:29 PM
vital22re's Avatar
totally a bro
maybe its the steering bump stop? mine makes a squeek poping sound at all the way right or all the way left
Charecter1
Nov 6, 2023 10:08 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
ItsJustD
Jul 7, 2015 07:49 AM
colinmil
Jul 6, 2015 04:03 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
