Installed a tow hook, question
Old Apr 12, 2009 | 05:04 PM
Tubbyfatty's Avatar
I bought a towhook from autozone the other day, then went to lowes and got some grade 8s. Well the hook doesnt mount right up against the frame, there about an 8th inch gap between the hook and the frame.
Heres a pic of what i mean. I threw some washers on there. What should i do? Is this alright?
Red line shows what im talking about.
sorry about the blurry ness, its raining outside.
Last edited by waskillywabbit; Apr 12, 2009 at 05:25 PM. Reason: Inappropriate Language
Old Apr 12, 2009 | 05:10 PM
bigt's Avatar
did you try shorter bolts??
Old Apr 12, 2009 | 05:11 PM
toyminator2000's Avatar
What happened to the factory hook?
Old Apr 12, 2009 | 05:13 PM
Tubbyfatty's Avatar
The bolts arent long. heres a better pic. its hitting this bracket thign.
Its hitting on the piece of metal before the first bolt. On the right.
Old Apr 12, 2009 | 05:14 PM
bigt's Avatar
got a dremmel
my hilux came witha tow hook on each side
my 4runners only have 1
Old Apr 12, 2009 | 05:15 PM
Tubbyfatty's Avatar
PO took it off or something. I bought it with out a hook or loop.
Old Apr 12, 2009 | 05:16 PM
Tubbyfatty's Avatar
Originally Posted by bigt
got a dremmel
Yea i have a dremmel.
Old Apr 12, 2009 | 05:17 PM
iamsuperbleeder's Avatar
yeah just knotch that metel with a dremel (or some elbo grease and a file ) so it'll clear the part of the hook where it's hitting
I guess the other option would be to heat the hook up with a torch and try to bend it down some, but good luck with that
Old Apr 12, 2009 | 05:21 PM
Tubbyfatty's Avatar
Haha, Im gonna be going through those tiny cutting disks, one bump and they break, i wish i had a grinder.
Wow im stupid, that was simple enough, i wish we could delete our own threads hahah.
Old Apr 12, 2009 | 05:26 PM
yeah an angle grinder might be easier
but there are those little stone grinding wheels for dremels, one of those might do the trick
bigt's Avatar
my dremmel little cutting disk last like 10 minutes.. should do that job with 1 no problems.. but yeah i love my grinder.. almost my favorite tool
Old Apr 12, 2009 | 05:28 PM
waskillywabbit's Avatar
Should be a 10.9 (Grade 8 equivalent) METRIC bolt. M12 x something
Metric 8.8 is a Grade 5 equivalent.
Tow hooks are dangerous at best. You'd be better off with a shackle hanger and shackle.
Old Apr 12, 2009 | 05:36 PM
abecedarian's Avatar
to clarify da wabbit's comment-
open tow hooks are dangerous, particulary ones that point downward since the strap can fall off the hook due to lack of tension or if there's a sudden rebound in the strap causing it to loose tension against the hook.
hooks with spring-loaded catches to prevent the strap from falling off the hook are okay.
Old Apr 12, 2009 | 06:46 PM
Tubbyfatty's Avatar
Yea i should of gotten one of those but i got this for $4, thank you friends at autozone ha.
I think napa has the ones with the springs.
tj884Rdlx
Aug 28, 2015 12:04 PM
1996Taco
Jul 20, 2015 12:02 AM
rushw
Jul 18, 2015 01:46 PM
88yodabasket
Jul 13, 2015 01:32 PM
Coreyr384
Jul 10, 2015 11:13 AM
