Bigger TB?
Old Apr 12, 2009 | 07:08 PM
turd_blower's Avatar
Bigger TB?
Has anyone ever successfully put in a TB out of a 5m or 7m supra? I know about the AFM, I want to know if this will compliment it.
Old Apr 12, 2009 | 08:19 PM
PirateMcgee's Avatar
I am also interested in this since I have a supra afm, built up 22re, and exhaust I think a supra tb could be helpful.
Old Apr 12, 2009 | 08:22 PM
abecedarian's Avatar
hmm... the tb and afm on the 22rte are the same as the 22re...
what exactly are you looking to add?
Old Apr 12, 2009 | 08:31 PM
iamsuperbleeder's Avatar
the elusive two letter phrase...
HP
Old Apr 13, 2009 | 07:53 AM
Anyone????????
Old Apr 13, 2009 | 08:54 AM
X-AWDriver's Avatar
I think it'll be a bit more complex to actually making HP since more air will also need a little more fuel to realize the HP gain or otherwise you might just see a leaner mixture and no noticeable gain anywhere.
Old Apr 13, 2009 | 12:18 PM
I was hoping to flow more air. Less restrictions. Won't the O2 sensor tell the ECU that the mixture is to lean and compensate?
Old Apr 13, 2009 | 12:33 PM
you would think
you'd have to do a little tweaking on the AFM (even with the Supra swap), so the ECU can make sence of the information from both the AFM and the O2 sensor, otherwise the the more air flow makes the AFM try to rich'n the mixure, but when the O2 see's that rich mixture, it will try to lean it out, and back and forth, and so on and so forth...
with a little time an effort, I'm sure it could be dialed in though
foampile
Dec 18, 2022 01:29 PM
Dparr2ndgen
Sep 8, 2015 01:06 PM
Steven.m.paulk
Aug 16, 2015 04:52 AM
Dakotaneu
Aug 15, 2015 07:24 AM
matrad
Aug 8, 2015 03:00 PM
