ooops!
Old Apr 13, 2009 | 08:48 PM
neq0323's Avatar
ooops!
OK so we are installing my ball joint spacers on my buddy's truck and snap! 2 bolts broken. where can i find the correct bolts or can i just go to the hardware store and match some up? should of stopped at 33lbs, bolts were not new though.
Old Apr 13, 2009 | 10:00 PM
scuba's Avatar
Try a hardware store first, If not 4crawler or SDORI..
Old Apr 13, 2009 | 10:22 PM
sinneDBTB's Avatar
same thing happened to me. mine kept breaking off because of the angle that the spacers would sit in the a-arm, i just reemed out the bolt holes with a drill.
where'd you get the spacers?
Old Apr 13, 2009 | 10:29 PM
algranger's Avatar
If you go to the hdwr store be sure to get grade 8's
Old Apr 14, 2009 | 12:41 AM
drew303's Avatar
Damn, now those are some bolts (assuming the 4 connecting the spacer and balljoint) you don't want to break.
Hardware store or a specialty bolt store. I got a store about 10 minutes from me that specializes in selling bolts and nuts, ha. Guess im lucky... but everytime i need em they're effing closed it seems heh
Old Apr 14, 2009 | 01:07 AM
Matt16's Avatar
I'd just tighten the other 2 more and maybe smear on some JB weld
Really good idea to listen to the torque specs. I'm glad they broke on you, for your own safety. If you overtighten a bolt, you weaken it and it could break on while driving possibly causing you to lose control.
WyoWill
May 4, 2015 05:56 AM
blindrunner
Dec 17, 2013 03:58 PM
ibdan61
Feb 24, 2013 12:25 PM
edgarsoriano35
Feb 22, 2013 09:23 AM
