Clutch Master Cylinder Replacment Problems
Old Apr 14, 2009 | 03:56 PM
randlejam's Avatar
Unhappy Clutch Master Cylinder Replacment Problems
I recently determined that my Clutch Master Cylinder had gone bad. So I purchased a new one and installed it. I was getting ready to bleed the line and when I tested the clutch pedal it was stuck. I am now unable to bleed the line because I can't even get the clutch pedal to "depress". It's as if the new Clutch Master Cylinder I installed is jammed. So I of course have not been able to bleed the line and am now asking YOTATECH users for help.
Any help would be greatly appreciated.
Old Apr 14, 2009 | 04:18 PM
Keyser Söze's Avatar
Check your clutch pedal linkage and make sure it's installed straight and properly and not cock-eyed.
Otherwise remove the clutch master cylinder and see if you can press-in the plunger with your thumb. You should be able to, and in fact it a good idea to always "bench bleed" the clutch and brake master cylinders before installing them.
Dillon1983
Jul 7, 2015 06:47 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
shadowbirdie
Jun 18, 2015 06:38 PM
TheManOutside
Jun 18, 2015 03:32 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
