Antenna WOES ideas??
Old Apr 9, 2009 | 11:09 AM
Bobzombie's Avatar
So about 6 months ago I replace my power antenna mast. My old one broke in half and the pipe gear had a short piece broken. The replacement went fine (it is super easy to replace) Worked flawlessly until this week. Now when the mast goes up or down. if makes a grinding noise in a fluctuating way
I will attempt to duplicate
growllllllgrowlllllllgrowllllllgrowllllllgrowlll
The mast does go all the way up and all the way down but it hesitates slightly during the sound change represented above.
I did remove the mast and it and its gear are fine no sign of wear.
Any ideas
Old Apr 9, 2009 | 11:34 AM
scuba's Avatar
Wd40, Lube, SuperGlide..?
try that...
Old Apr 9, 2009 | 11:38 AM
4Crawler's Avatar
I usually spray my power antenna with a dry silicone spray. Soak it down well w/ antenna fully up, then lower and raise it a few times to get the silicone into the moving parts.
wyorunner's Avatar
tacoma whip mod, like i have on my 02.
Old Apr 9, 2009 | 11:43 AM
tj884Rdlx's Avatar
1. make sure there's no broken bits of the plastic toothed strand that goes into the gears from the old antenna mast. sometimes they break off and don't allow the new one to seat all the way in. you will need to open the motor to check for bits.
2. check the gears and new antenna for teeth damage. if the teeth are worn down, the gears will just spin and not engage with each other, and then its time for new motor if its on the gear side (rather than mast's strand side)
3. replacement mast may be incorrect, and teeth may not be big enough to engage in your motor.
use lithium white spray lube inside your motor, not wd-40
good luck bro!
Old Apr 9, 2009 | 11:46 AM
mswfox's Avatar
Guest
Tacoma whip mod x2! It looks better, and you don't have to keep worrying about it anymore. I plan on doing it as soon as my original motorized antenna calls it quits (120K miles and counting).
Old Apr 9, 2009 | 12:02 PM
Bobzombie's Avatar
I looked at the teeth of the mast they are fine. My guess is the teeth on the motor are worn.
No it is the right mast, I am certified (see sig) lol
Thanks for the Ideas. I think for know I am going to load it up with grease and hope that works. And then I might do the whip
Wyo how does the whip work for your radio??
Old Apr 9, 2009 | 01:11 PM
tj884Rdlx's Avatar
did you open the motor box and peek inside already? if not, make sure last function was antenna up before power off. look in there and make sure them teeth are ok and there's no old bits. also, turning the mast with your fingers will turn that gear strand, maybe they're just not lining up right inside. if you've got the growl growl, it should be just missing. hm.
if it is motor bad, you can get a generic on fleabay if you like the power functionality.
link: http://cgi.ebay.com/ebaymotors/POWER...1%7C240%3A1318
otherwise, as described, a rubber whip job is pretty durable. also, check this out.
link: http://cgi.ebay.com/ebaymotors/BOSCH...1%7C240%3A1318
Old Apr 10, 2009 | 09:26 AM
wyorunner's Avatar
whip works good, just like any other antenna, except its not as fancy. its real easy to do too. BUT, if you do end up pulling you motor apart and find something wrong with it, i have the one out of my truck that im pretty sure is still good if you need to replace yours. and i think itll work in your truck but not sure.
Old Apr 10, 2009 | 01:06 PM
iamsuperbleeder's Avatar
what is this Tacoma whip mod?
Old Apr 10, 2009 | 01:20 PM
94Runner4x4's Avatar
mine has been doing the same thing for the past 3 or 4 months....I don't even hear it now, as long as it goes up and down it will eb the least of my worries.
Old Apr 10, 2009 | 01:46 PM
I don't even HAVE an antenna I broken mine off, and ever since I installed my new head unit, I get prefect reception without it! I have a whole new assembly and everything, still wrapped in plastic in the garage, buy I'm not going to fool with it as long as it works
oh but mine's just a regular antenna, not a power antenna
Old Apr 10, 2009 | 05:21 PM
wyorunner's Avatar
the tacoma whip mod, is a mod that replaces eletric antennas with a solid whip, which is what the tacomas have. you take out the motor from inside the fender put a mount in its place and screw the antenna in on top of the mount. search it youll see what im talking about.
Old Apr 10, 2009 | 06:14 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Same antenna that the deluxe Toyotas' came with....non motorized.
Old Apr 21, 2009 | 02:47 PM
jimig's Avatar
http://www.4runners.org/writeups/whip/index.html
Old Apr 21, 2009 | 03:03 PM
Bobzombie's Avatar
Well my solution was to just unplug the motor. No more noise and as long as you unplug in the UP position the signal strengh is the same and the antenna doesnt move!! It sucks for automatic car washes but they usually give me the evil eye If I try to take my muddy a$$ Runner through that lol
DeathCougar
Apr 1, 2018 11:29 PM
mussy01
Dec 13, 2016 08:20 PM
corey519
Aug 12, 2015 11:12 AM
Bawlzdeep
Aug 2, 2015 08:35 PM
TDonkey
Jul 26, 2015 10:14 AM
