front end noise?
Old Apr 16, 2009 | 09:03 AM
69stepside's Avatar
front end noise?
i just had my auto hubs replaced with manual one while i was in there i put new rotors and inner and outer bearings. the ? is i seem to be hearing a noise like a hum not a grind nor a clatter is this normal with all the new stuff or is this a bad sign. the truck drives good no wierd feelings. any suggestion before i spend dough on mach.
Old Apr 16, 2009 | 04:41 PM
xXbrutalXcoreXx's Avatar
are you driving with the hubs locked or unlocked?
Old Apr 16, 2009 | 06:10 PM
PlugItIn's Avatar
its not normal...should be quiet. Very hard to diagnose this problem with what you explained. It might be the caliper stuck out a little bit holding the brakes on the discs maybe? and like said above, make sure unlocked and not in 4wd
Old Apr 16, 2009 | 07:02 PM
69stepside's Avatar
hubs are in the unlock position the brake thing sounds like it might be right i it seems to happen after stopping thanx for info
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
Jonny246
Jul 12, 2015 04:51 AM
