I need 2/10ths of a quart of royal purple... or do I?
Old 04-15-2010, 09:54 AM
poynter's Avatar
So my manual trans has been making some noise but it has not effected the driving or shifting at all. I figured instead of swapping in another I would try and make this one last till it dies. I went and picked up some royal purple gear oil 75w90 and MY GOD ITS EXPENSIVE! 19.99 a quart here at advance auto.
W56 calls for 3.2 quarts but they only had 3. Not that I would have spent 20 more bucks for a smidgin of gear oil but now Im wondering what I should use for that other .2 quarts when i fill the trans back up. Another brand of synthetic maybe? Can is use the same oil in the t-case or diffs? If so it wouldnt be bad to have some extra...
Old 04-15-2010, 09:59 AM
904_runner's Avatar
i remember running the expensive oils. then it leaks out or you break and have to discard it anyways.
Now its the $11 gallon from autozone..
Do whatever you think is best.
Old 04-15-2010, 10:30 AM
waskillywabbit's Avatar
Just hook up 3.2 of your spark plugs it will balance it out
Old 04-15-2010, 04:07 PM
516593812's Avatar
i'm not a mechanic- but in all my years of wrenching on & maintaining my own cars (honda cars & toyota trucks) i've learned that it's usually best to use the cheap stuff on higher mileage vehicles- i remember on my '90 2wd 22r PU i had before this one, no leaks at all, but the day i ran mobil 1 full synthetic, it started to develop a slight leak, now i use Supertech (Walmart) $10.50/ 5quart jug in my current rig- i just change it regularly. The same thing hapened on my '95 Accord, around 200k miles the tranny started to shift a little rough, so i thought i'd be "smart" & do an MTF change with some expensive full synthetic oil- it started leaking (just a bit) shortly thereafter.
just some thoughts from my own experiences......
Old 04-15-2010, 06:47 PM
iamsuperbleeder's Avatar
lol, wut?
Old 04-15-2010, 07:50 PM
GenXr's Avatar
Originally Posted by poynter
...Im wondering what I should use for that other .2 quarts when i fill the trans back up. ... Can is use the same oil in the t-case or diffs? If so it wouldnt be bad to have some extra...
Yes, use it in your diffs. I have it in my diffs and trans, same weight front to back and the 10W30 in the crankcase.
Old 04-15-2010, 11:43 PM
limon32's Avatar
You can put anything in with it to make up the last bit, you'll still get the benefits of the full synthetic for the most part.
I agree with other posters though, in a play rig like mine I run cheap stuff because I end up draining it for one reason or another about every 6 months...
Old 04-16-2010, 12:17 PM
surf4runner's Avatar
Originally Posted by iamsuperbleeder
lol, wut?
he means only add 1/5qt for full capacity.
Old 04-16-2010, 12:36 PM
Matt16's Avatar
why dont you check if you even need it by checking the fill level bolt on the (driver's?) side of the tranny. Usually, you arent able to drain all the fluid from the tranny in the first place and you don't need the full fill capacity to totallt fill the tranny to the bolt hole on the side.
Old 04-16-2010, 07:36 PM
peow130's Avatar
8.99 a quart for 10W30. I just put 6 quarts in my camaro today .
I got the 15.99 deal on the castrol GTX for my pickup.
dzldust
7
10-06-2015 05:39 AM
irv
10-01-2015 09:49 PM
puddlepirate
09-29-2015 08:02 PM
travisamorgan
09-02-2015 01:00 PM
viesail
08-30-2015 06:37 PM
Quick Reply: I need 2/10ths of a quart of royal purple... or do I?
