ZUK coils???
Old Apr 14, 2010 | 09:04 PM
Shawn6string's Avatar
ZUK coils???
Finally getting aroung to doing the ZUK coil spring install. Can anyone pass me a link on where I can get a pair. Seems everyone is getting them off ebay but I cant seem to find them.
I understand the 12 inch ones will put my 88 4runner back to the right highth and the 14 inch ones will give a lil lift. I want to get the factory highth and a better ride. Any suggestion.....
Old Apr 14, 2010 | 10:21 PM
toyNG's Avatar
http://gearinstalls.com/coilinfo.htm follow the links on this site
Old Apr 14, 2010 | 10:25 PM
MooneyFWD's Avatar
Here you go. Just got mine in the mail today!
NEW RACING COILOVER SPRING,2 1/2" ID X 14" TALL
http://cgi.ebay.com/ebaymotors/NEW-R...#ht_2159wt_722
Old Apr 14, 2010 | 11:41 PM
Philbert's Avatar
Check out my sig for the link to my diy with pics galore....
Old Apr 15, 2010 | 06:37 AM
Those are 14 in, are they gonna give a lil lift or be stock highth?
Old Apr 15, 2010 | 06:56 AM
snobdds's Avatar
I put 12 in. 150lb coils and it put me back at stock height. The 14 in coils I bought were to high for my truck, although the 4 runner is a little bit heaver. Best mod I've done yet!
Old Apr 15, 2010 | 08:25 AM
MooneyFWD's Avatar
I have a 4 inch lift and 3 inch blocks in the back that will be coming out. I got the 14" 125# coils to hopefully get the back end of my truck back up 3".
That same seller has several auctions and you can pick your size during payment.
Old Apr 15, 2010 | 11:26 AM
Sweet....thanks
Old Apr 15, 2010 | 04:37 PM
annoyingrob's Avatar
I just used a pair out of a 82-86 Toyota Supra, cut a loop off, and stuck them over my bump stops
Stock ride height, and handles a big load quite nicely. A little bouncy when empty.
Old Apr 27, 2010 | 07:40 AM
More questions....Does anyone know about how much lift the 14 in. colis will give.. I am thinking of putting 2 in spacers on the front and coils in the back..Any feed back would be helpful....
Old Apr 27, 2010 | 02:46 PM
MooneyFWD's Avatar
I put the 14" 125# springs in, removed 3" blocks, and I'm back to where I was with the 3" blocks. I had pretty flat leaves already if that makes a difference.
Unfortunately, I was too excited to put them on to take any measurements!
Old May 5, 2010 | 01:10 AM
AKZEP69's Avatar
zuk netted 5" plus with 14's
Put the Black Magic 14" 150lbs on my 88 runner last weekend with new skyjacker nitro shocks all around and ended up 5.125" right / left 5.25", went from ass saggin to lookin like a 60's street rod. (L=9.75" to 15" & R= 9.625" to 14.75")
the ride with the 14's really leans in corners so im looking to add a rear sway after i swap to the 12's.
FYI logistics in alaska is bitch sometimes / i hope to receive 12's by this weekend
I will follow up after 14/12 swap with pix from both sets.
Old May 5, 2010 | 11:43 AM
Duckie's Avatar
I put a set of 14s @ 125lbs in the back of my runner to match my pro-comp 4" front. With the back on it's almost leveled out, with the back off it's perfect.
Old May 6, 2010 | 11:10 AM
Thinking of going with the kit on wabfabs page....2in spacers in the front and add a leaf in the rear for a 2in lift...i emailed him and he said that he had installed this setup on several trucks and it works nicely with some new shocks...Has anyone else tried that setup?
Old May 6, 2010 | 12:13 PM
Ruined Adventures's Avatar
I finally received my coils after some shipping errors...I bought the TJ coils (front) and I'm going to try the weldless ZUK mod like DJ99 did. The TJ coils are 17 inches! So I also would like to know how short I need to cut mine. I'm also looking for the stock ride height, but wouldn't mind a little bit of a "raked" look to it. Anything beats that saggy rear. I guess I'll try 14" first...I can always cut more off later. I'd just like to get it right the first time.
I will let you know how this turns out.
Old May 7, 2010 | 06:38 AM
cool thanks
Old May 9, 2010 | 06:52 AM
thralldad's Avatar
When I did mine I cut the coils to 10.5" and it was just right for stock height. Mine were off a Fox mustang and they fit over the bumpstops fine.
punks_is_4x4
May 31, 2016 06:03 AM
the_supernerd
Oct 1, 2015 09:20 PM
oldblue
Sep 28, 2015 04:07 PM
mojo4x420
Sep 16, 2015 08:07 AM
