strength of a 5 speed manual
Old Apr 16, 2010 | 08:20 PM
lec5her's Avatar
does anyone know the hp and torque rating for the 92 5 speed i think it is a g series
Old Apr 16, 2010 | 08:57 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
For which engine? The 22re or the 3vz? The 3vz manual tranny is an Rf150
Old Apr 16, 2010 | 10:30 PM
PismoJoe's Avatar
Your posting is kind of confusing, wouldn't you be asking how much hp is lost through this drivetrain setup?
Unless you worded it wrong, and meant to say "what is the hp and torque of a 92 3.0 or 22re w/ a mtm" then the answer is:
3.0L 3VZ-E
At introduction output was specified as 145 hp (108 kW) then later bumped to 150 hp (112 kW) at 4800 rpm with 180 ft·lbf (244 N·m) of torque at 3400 rpm
2.4L 22R-E
output was was specified as 112 hp (84 kW) at 4600 rpm and 142 ft·lbf (192 N·m) at 3400 rpm.
Transmission Possibilities:
4WD North American Products:
R150F (3VZ-E, F Suffix=4WD, there is a R150 2WD in later models)
G58 (22R-E)
W56 (22R-E)
2WD North American Products:
W46
W55
Last edited by PismoJoe; Apr 16, 2010 at 11:13 PM. Reason: wrote 2.7 instead of 2.4
Old Apr 16, 2010 | 10:35 PM
89silverpu's Avatar
He's asking how much horse power torque can a 5spd transmission handle from an engine. (possibly for an engine swap?) To help get you a better answer...do you have a 4 cyl transmission or a 6cyl transmission.
Old Apr 16, 2010 | 10:41 PM
PismoJoe's Avatar
Ohhhhhhh I see wow I thought I tackled that one from all angles lol
But yes, what engine are you running now and what do you want to be running?
Old Apr 16, 2010 | 10:47 PM
Matt16's Avatar
The transmission doesn't have a HP rating like perhaps some Mopar stuff might, but Toy trannies are pretty stout. Its going to depend to a large extent how you're going to be using the truck- rock crawling, mud bogging, highway cruiser, drag racing (ha ha)...
Old Apr 16, 2010 | 10:51 PM
PismoJoe's Avatar
I've heard that putting a 350 small block together with a Toyota transmission in general is not the best way to go....but I could be wrong!
Wait, you don't drag race your toyota???
Old Apr 16, 2010 | 11:04 PM
NwRunner's Avatar
Originally Posted by PismoJoe
2.7L 22R-E output was was specified as 112 hp (84 kW) at 4600 rpm and 142 ft·lbf (192 N·m) at 3400 rpm.
I believe the 22R-E is a 2.4, the 2.7 is the 3RZ
Old Apr 16, 2010 | 11:12 PM
PismoJoe's Avatar
good call...I mixed up that detail. I have a 2.7L 3RZ-FE and a 2.4L 22R-E, but that is the correct hp/torque for the 22R-E
Its really late I need to go to bed now lol good luck on that!
Old Apr 17, 2010 | 11:32 AM
tc's Avatar
tc
The r-series tranny in the V6 trucks is essentially the same as what was in the twin-turbo supras IIRC. In other words, it will likely hold whatever motor you put in front of it.
If you have a 4 cylinder tranny, the issue is likely to be the output/tcase. The 21 spline tcase input is usually the weak point. The turbos and V6 trucks had a significantly stronger 23 spline setup.
Old Apr 18, 2010 | 09:37 PM
lec5her's Avatar
sorry it is a 22re and i would like to put a ford 302 5.0l
Old Apr 18, 2010 | 09:39 PM
lec5her's Avatar
ford 302 5.0L lol
Old Apr 18, 2010 | 09:42 PM
toyota4x4907's Avatar
Originally Posted by lec5her
sorry it is a 22re and i would like to put a ford 302 3.0l
302 3.0L?...
try more like 5L
Old Apr 18, 2010 | 09:44 PM
lec5her's Avatar
yeah thats wat i ment
Old Apr 19, 2010 | 04:42 AM
RustBucket's Avatar
I think PBB is better equipped to handle your question.
Old Apr 19, 2010 | 05:36 AM
4runnerteen's Avatar
Yea I know nothing about the 302. I suggest shooting pbb a Pm. He knows everything
Old Apr 19, 2010 | 08:09 AM
PismoJoe's Avatar
this thread is failing unless someone chimes in that has put a small block ford or chevy in front of a toyota drivetrain.
Old Apr 19, 2010 | 08:17 AM
rattlewagon's Avatar
I would send 5.0 Fordota a pm. He has a ford v8 hooked up the the stock 5 speed I think....
Old Apr 19, 2010 | 09:43 AM
allnmstkn313's Avatar
G-series? eh 200 horse perhaps, W series is stronger.
W-series? seen them hold up under 300 longterm.
R-series? Been driving a r-151 behind a supercharged 5vzfe for several years now.
Old Apr 19, 2010 | 10:30 AM
toyminator2000's Avatar
What allnmstkn313 said, Except I think the G58 will probably hold up to a little more than 200HP. But it is one of the weaker manuals Toyota put in trucks between 85-95. The w56 is a direct swap out for the G58 as long as the t-case is included.
Liadrin
Apr 25, 2022 02:54 PM
young buck
18
Aug 27, 2018 02:40 PM
Liadrin
Sep 1, 2015 06:44 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
jjrbus
Jul 19, 2015 02:06 PM
