91 22RE Starting Issues
Old Apr 14, 2010 | 01:10 AM
KcYotaChick21's Avatar
Ok so my re was rebuilt last summer. Its been running amaazing and stock wheels like a dream but in the last 2 months it started surging while i was driving and got to the point where it completely died while driving. It would not start for about 10 to 15 min but randomly would decide to start. Also it would randomly decide not to start at all, but if i cranked on it and kept trying it would start after about 15 -20 min. I replaced the Fuel filter, spark plugs, fuel pump, efi Relay & checked EFI fuse. Im lost on what to do. It ran great after the spark plugs and pump replacement for about 3 weeks to a month and tonight it decided to not want to start for about 20 min I tired and then it finally did. I brought it home, it started again and then when I went to leave about 10 min later it wouldnt start. I also checked to make sure its not vapor locked and loosened my gas cap because I was told it could cause it but it still wouldnt start. Im not quiet sure what else it could be or what to check. Any ideas would be great.
Old Apr 14, 2010 | 01:30 AM
vital22re's Avatar
totally a bro
when its not starting, check to see if its because of no spark. Are you flooding your motor because teh cold start system is not properly working?
Old Apr 14, 2010 | 01:37 AM
Its getting spark I checked that, & IM not sure about the cold start system? Its like its not getting fuel at all if that makes sense but after trying for a while it randomly starts... How would I check the Cold start system
Old Apr 14, 2010 | 01:40 AM
vital22re's Avatar
totally a bro
next time it wont start, you can put power directly to the fuel pump via the diagnostic port under the hood. Maybe your cor relay is not working or your afm is not sending the signal to pwer the cor relay that sends pwer to the fuel pump.
Old Apr 14, 2010 | 01:43 AM
Hmm I will try that. Its just really odd.. Like It decides to not start but then later it will start right up doesnt make sense. I thought the fuel pump and fixed it because It ran great with no problems for about a month but now it did it again tonight... Damnnnn Thank you Ill try that
sonic concepts
Aug 16, 2025 03:13 PM
Sandman
Jul 23, 2015 08:15 PM
puffin04
Jul 10, 2015 09:17 PM
slider417
Jun 22, 2015 10:18 AM
bobbybouche
Jun 18, 2015 10:22 AM
