please help!! sputtering / hessitation
Old Apr 17, 2010 | 10:23 PM
justinmnhall's Avatar
just put together a 90 22re 4runner 5sp. has a street rv with a 261c cam over sized valves. put in new vacuum lines and new fuel and new fuel filter after running it for a bit with 4yr old gas but new filter. adjusted valves and timing to factory setting. new cap, rotor wires. when i got it running it runs fine. misses a little when cold above 2700 rpms. when warm misses quite a bit at same and up rpms. when i gun it no lag or sputter only when i am cruising around 2700 and up with no petal pressure does it miss. i have put seafoam thru the vacuum system before the smog test and i just added seafoam to the oil.that has helped a little bit. luckily the smog was a test only. but the h/c were way, way too high!
{%co2} {%o2 }{ hc max }{hc gp} {hc meas}{co% max}{co gp} {comeas}
12.7 2.3 120 330 363 1.00 2.50 .71
12.9 1.8 180 270 788 1.00 2.50 .95
timing was set at 8 deg. I have set timing to 5 now and replaced the pcv valve since the test. 192xxx i am sure it is the after mark cat. before test and since then i have been running 91 oct gas. tested distributor, coil tps, mas, carbon canister, egr and egr modulator. any suggestion or advice???
Old Apr 18, 2010 | 06:36 AM
yayfortrees's Avatar
Tell me you flushed out that 4 year old gas and put in new. If not, you need to do that next.
Old Apr 18, 2010 | 06:45 AM
oh ya. replaced gas as soon as it was road worthy
Gutted91
Jan 3, 2020 09:48 AM
Marley2984
Dec 6, 2015 05:19 AM
Firefightersink15
Nov 23, 2015 10:32 PM
93RedKrawler
Sep 25, 2015 04:03 AM
Gutted91
Sep 17, 2015 05:44 PM
