95 pickup with 22re won't start.
Old Nov 18, 2021 | 05:03 PM
catmandu22's Avatar
I have a 95 Toyota pickup that will not start. Truck was running then sat up for one month. Went to start and some crazy ˟˟˟˟ with the dash lights are going on. So once I turn the ignition switch to the on position, the dash lights come on then slowly fades away. Then I turn over to start the engine and nothing. all light go away and no sound. like some type of amperage draw. Changed the battery and starter is 2 months old. Also installed a new start relay. The radio would flicker on and off so I thought maybe it was shorting out, causing the problem. I pulled the radio and disconnected. No change with the problem. Anyone knows what I could check?
Old Nov 19, 2021 | 07:47 AM
Paul22RE's Avatar
5 Year Member
How's the grounds under the hood? How's the battery negative cable & ends? Battery connections tight? Connection to the new starter tight & corrosion free?
Old Nov 19, 2021 | 11:11 AM
5 Fists's Avatar
Like Paul22RE said, check all your grounds. When I first got my 4runner and had an intermittent radio issue and some other random electrical things, cleaning the grounds in the engine bay made a huge difference.
Dreedy1976
May 2, 2017 08:25 AM
RAWarmack
Mar 4, 2017 09:00 PM
GreenMachine954
Dec 25, 2012 07:14 PM
bio6040
May 4, 2011 09:56 AM
