TCM problem
Old Nov 16, 2021 | 01:41 PM
Candersen66's Avatar
TCM problem
I have a 1994 4runner 3VZE 3.0 Auto Trans A340H, Transmission wouldn't shift when I bought it no transmission/engine codes, I rebuilt the transmission and transfer case (I am an ASE mechanic retired) followed the FSM, Still won't shift after, so tested and replaced the park/neutral position switch=bad, TPS was replace, No 2 Speed sensor replaced, everything else tested good, but when checking at the ECM/TCM i have power going to Solenoids 2,3, and 4 and no power to S1 should be just the opposite, has anybody else run into this? no way to query the ECM it is OBD1, does this sound like an ECM/TCM?
Old Nov 16, 2021 | 05:03 PM
scope103's Avatar
Originally Posted by Candersen66
... no way to query the ECM it is OBD1, ...
Will it shift (using the shift lever) with the solenoids all disconnected? If not, you are unlikely to have an ECM issue.
Have you queried for trouble codes? http://web.archive.org/web/201408161...31diagnosi.pdf
Have you done the FSM electronic diagnosis? http://web.archive.org/web/201408160...34electron.pdf
Old Nov 16, 2021 | 07:40 PM
Bad TCM
Yes it will shift manually with the solenoids disconnected, with them connected solenoids 2,3,4 are activated, I did replace all 4 solenoids.
Old Nov 16, 2021 | 07:54 PM
Tcm
Yes I have been through the FSM electronic diagnosis except trying another TCM ECM
jjrbus
May 18, 2016 02:22 AM
Qyota
15
Jul 25, 2012 05:34 PM
iselloil
May 25, 2011 06:38 AM
Postmannb
Apr 14, 2011 01:01 AM
mac9968
Aug 25, 2009 04:17 PM
