HELP, loose power cable
Old Oct 18, 2021 | 04:12 AM
10ofclubs's Avatar
hello , so I was working on my 4runner and notice this red wire that didnt go to anything. Does anyone know where it bolts up too?
File Type: pdf
Old Oct 18, 2021 | 09:28 AM
keycw's Avatar
5 Year Member
you might start by seeing what doesnt turn on. or maybe following the cable back to where it comes from. looks like your starter cable. does the truck start?
Old Oct 18, 2021 | 10:09 AM
RAD4Runner's Avatar
Like KeyCW says ^^^.
Was truck working before? Why are you working on it? Our sense are most important diagnostic tools. Wanna tell us what you see, hear, feel, smell about the truck that is not normal?
How can we help if we do not know year-engine-transmission-trim? Include all that on you signature.
Old Oct 18, 2021 | 11:39 AM
2ToyGuy's Avatar
If I were to guess, I would say it's the high power cable that runs from the battery down to the body of the starter. Bolts onto a relatively large screw post on the starter, and should have a rubber protector that slips over it.
All that is presuming, as it looks like, that's over on the passenger side. If it's actually over on the driver's side, it could be the cable that runs from the alternator body to the battery. Same screw-post and rubber cover set up.
It IS possible that the PO replaced the power cable going down to the starter, and just never pulled the old, original, cable out.
But I really think it's the starter power cable.
Pat☺
Old Oct 18, 2021 | 08:52 PM
ZARTT's Avatar
Hi:
Pat is correct.
That is the passenger side of the car, and that is the high current lead from the battery to the starter.
Either it has been left there after a replacement was installed in the cars past life, or you took it off when you were working on your car, and forgot to put it back on.
The possibility exists that the other end is still on the + battery feed. If it accidently goes to ground you will have a massive fireworks display.
Be extremely careful.
Good Luck
Art.
Old Oct 19, 2021 | 12:32 PM
2ToyGuy's Avatar
Originally Posted by ZARTT
Hi:
Pat is correct.
Good Luck
Art.
Yeah, that cable is really lousy for arc-welding. I would avoid that at all costs
Absolutely remove both battery cable from the battery until you find out for a certainty what the other end of that cable is going to. If it's a left-over after replacing the + battery cables, just pull it completely. It's a waste of sace.
If it's still connected to the battery, bolt it down to the starter before re-attaching the battery cables.
The fire works you can get from it might be a exciting and colorful display, but really, not good for the battery or cables.
Good luck!
Pat☺
Old Oct 21, 2021 | 01:50 AM
10ofclubs's Avatar
hello everybody sorry about that been busy these past couple days. The car is 91 sr5 4wd , the car starts runs sluggish but due to needing a maintence. So Im having power steering issues and I saw that power cable and had no clue about it.
Old Oct 21, 2021 | 06:54 AM
RAD4Runner's Avatar
You still haven't traced it end to end? Yes, it could be this big cable:
Old Oct 21, 2021 | 11:46 AM
2ToyGuy's Avatar
If that cable is a remnant from the original wiring that got replaced, so is no longer used, I would still pull it out completely. Heck, if nothing else, you have a spare on the shelf.
You really don't want it touching something it shouldn't, and it will. Murphy's Law requires it.
Good luck!
Pat☺
rafuzv
Jun 25, 2012 05:19 PM
Djlarroc
Oct 29, 2007 04:31 AM
johnnyutah36
May 7, 2005 10:41 AM
AgRunner06
Apr 5, 2004 07:48 AM
