Transmission fill
Old Nov 16, 2021 | 10:38 AM
spazman's Avatar
Transmission fill
Hi folks,
1995 RWD pickup, 2.4 5-speed. Just finished with replacing the oil in my transmission. I had to do my speed sensor anyway, and I lost about half a quart of oil when I pulled the sensor out of the transmission, so I just did it all this afternoon. I scoured the web and this forum looking for guidance on fill, and I came away with 2.3-2.7 quarts. Is that correct? I had to fill with the truck on an incline, nose up, so it would have ended up way overfilled if I had waited to observe for fluid overflowing out the fill bolt hole.
I took a short test drive, and first gear is a little less notchy now. Fill must be in the ballpark for the gears to work, but I was just hoping to have some confirmation that my ~2.5 quarts was adequate.
Thanks!
Old Nov 16, 2021 | 12:58 PM
Paul22RE's Avatar
5 Year Member
Only way to know for sure is park on level ground and remove fill plug to check.
Bridger McKinney
Apr 10, 2021 06:44 AM
Rusty Bob
Mar 2, 2020 05:59 AM
bootown
9
May 13, 2010 07:02 PM
GhostriderTx
Dec 18, 2007 04:36 PM
kenandjenn
Jun 10, 2006 06:25 PM
