I changed my 5 speed dope... have a ?
Old Jun 10, 2006 | 04:06 PM
kenandjenn's Avatar
Guys, I changed the oil in my 5 speed today and use Mobil 1 Syntheic. I have a 2.4L 2wd and the manual called for 2.7 qts of dope.
I measured it out EXACTLY, but due to the fill hole being hard to get at, I spilled a little here and their along the way. I tried to add the amount I thought I spilled at the end.
Is it a big deal if its a little + or - 2.7 qts? Is their a procedure to check the fluid through the fill hole?
Its shifting fine and their are no noises.
Just wanted to check.
Old Jun 10, 2006 | 05:30 PM
youngbuck's Avatar
You are suppose to fill it up until it starts to come out of the fill hole, which should be roughly whatever the manual says (but not always exactly). The way you check the oil level through the fill hole is by sticking your finger inside and seeing if the oil is right up close to the fill hole.
Old Jun 10, 2006 | 05:42 PM
oly884's Avatar
Guest
Yup, that's the best bet. Just put some more in till it just starts coming out the fill hole and you'll be fine.
Old Jun 10, 2006 | 06:08 PM
kenandjenn's Avatar
Good, it started doing that a little as I finished the last quart off. I'll check it again tommorrow.
Thanks guys.
Old Jun 10, 2006 | 06:22 PM
Elton's Avatar
so your truck is on drugs ???
Old Jun 10, 2006 | 06:25 PM
kenandjenn's Avatar
Well I wouldn't mind giving it some laughing gas, but It might not last to long so I better not....
smthwsn357
May 1, 2024 07:28 AM
montanatruck
Feb 26, 2017 07:07 AM
coffey50
Jul 28, 2015 10:55 AM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
