1990 4Runner Antenna Nut
Old Dec 9, 2021 | 06:38 PM
jay4runner's Avatar
I am replacing my fender and therefore need to unattach the antenna from it. The first part is easy - unscrew the mast from the base - piece of cake. Step 2 I assume is to remove that little chrome (crown style) nut from the top of what is left. That thing won't move and after trying to coax it along by tapping between the 'ridges' with a screwdriver i have found that the top of this nut is very brittle and half of the 'ridges' have now broken off. I suppose because this nut has been on there for over 30 years it is a little stubborn. Any suggestions on what I can/should be doing now to get this thing off? Is there a trick to it? Thank you in advance for any/all suggestions.
Old Dec 10, 2021 | 04:51 AM
scope103's Avatar
Did you try the wrench made for that purpose?
Amazon Amazon
I was able to get mine off by gently tapping it with a screwdriver, so I can't tell you what "size" wrench you need.
Old Dec 10, 2021 | 06:56 AM
Paul22RE's Avatar
5 Year Member
Mine was a pain too and ruined the bezel getting it off. Good thing it is not discontinued, part# 86392-89105. Toyota calls it "ORNAMENT, ANTENNA"
https://www.amayama.com/en/part/toyota/8639289105
Old Dec 10, 2021 | 11:38 PM
jay4runner's Avatar
Originally Posted by scope103
Did you try the wrench made for that purpose? https://www.amazon.com/Powerbuilt-64.../dp/B004KED7KW
i guess I should have tried one of these proper wrenches before breaking the thing
Old Dec 10, 2021 | 11:42 PM
jay4runner's Avatar
it is actually the little chrome not at the top of this black plastic piece that is what is causing the trouble. I assume once I get it off then this black piece will pop right off.
lhong1683
Oct 27, 2018 01:35 PM
xzyragon
Dec 23, 2008 07:54 AM
ato178028
7
Oct 24, 2008 11:32 AM
91Toyota
Feb 23, 2008 07:27 PM
LV_4Runner
11
Jun 24, 2005 05:43 AM
