Front sway bar
Old Dec 19, 2021 | 07:51 PM
MichaelKLerner's Avatar
Front sway bar
88 2wd hauling over a thousand lbs cargo: I don't have any sway bars, front or rear, and I figure I should. What I don't understand is how/where to fasten the endlinks to the existing suspension. I'm going a bit mad trying to understand. Please help.
Old Dec 20, 2021 | 06:00 PM
millball's Avatar
There's holes in the lower A arms to accept the end links.
Old Dec 20, 2021 | 07:35 PM
Thanks!
Thank you for sir!
Old Dec 20, 2021 | 07:50 PM
What about the rear?
1988 pickup with 8 inch rear: What about the rear. Are there end links? Where do they attach? Does it matter whether you have the 8 inch rear or the 7.25?
Old Dec 20, 2021 | 08:44 PM
millball's Avatar
Don't think the leaf spring rears had any sway bars.
Coil springs rears did though.
Old Dec 21, 2021 | 06:20 AM
rattlewagon's Avatar
They add sway bars to the rear of tundras. They put the bar on the axle and tie the link ends to the frame. Not sure if this helps, just a different way of thinking.
If your loading up your truck so that its swaying going down the road... you may also need better springs and probably brakes.
Old Jan 6, 2022 | 09:56 AM
What size sway bar is best?
88 22r DLX with max height allowed by the front torsion bars:
I think I have decided that the rear end of the truck, which is where most of the weight is, is not the problem because I have seriously built up springs and good shocks. Therefore I have decided to focus on the front first.
I have a choice between 3/4 inch sway bar and 1" sway bar and wondering what those with more experience think is best.
And also what brand makes the best attachment hardware?
91diesel
Jan 24, 2010 04:09 PM
86yota2wd
Feb 1, 2009 11:37 PM
Alex 400
Sep 29, 2007 11:07 AM
geoff
Jun 29, 2007 01:37 PM
zamboni95
Jul 30, 2003 01:11 PM
