quick and dry on replacing a pitman arm
Old Oct 6, 2019 | 09:21 AM
keycw's Avatar
5 Year Member
I read about guys having loads of trouble replacing these pitman arms, more often than not I see that its because they don't have the right tools. sometimes they really are just froze all to hell on the shaft. I replaced mine in about 30 minutes this weekend.
let me start by saying that, like many others here stress, Toyota parts are the know-all end-all of parts. I was in a bind for a pitman arm about a year ago and resorted to getting a moog form an autozone or whatever because I was traveling. anyways, a year is all I got out of it. joint was destroyed and popping like crazy. OEM Toyota is still available form your local dealer. my dealer got it for even less than toyotapartsdeal, I didn't pay for shipping, and they got it in 2 days.
I found it easiest to do this with straight tires, although the shaft and pitman arm do have alignment lines on them.
hit the shaft the night before with some PB or rust catalyst, whatever you like.
youll need a 32mm socket to remove the nut, not exactly common so plan accordingly, a pitman arm puller, a brass hammer, and a wrench for the castle nut on the steering linkage, and a pair of pliers for the cotter pin.
this is the oem part number
your 32 mm socket required for removal and installatin of the nut, which youll need to reuse.
my socket set is a 3/4 inch drive which makes removal pretty easy
save these...
use a brass hammer and impact the flat spot on the linkage to jar it loose.
apply the pitman arm puller, put some tension on it, and give it a few wacks with your hammer to break it free
all better. torque spec is 130 foot pounds.
Old Oct 10, 2019 | 11:20 AM
old87yota's Avatar
Thanks for posting this nice and quick little write-up!
Old Oct 10, 2019 | 08:22 PM
Melrose 4r's Avatar
5 Year Member
Good one, Cody.
That special puller is available as a loaner from many parts stores.
I bought my 32mm 1/2” drive socket from Lowes it was not available anywhere else locally.
Old Jan 24, 2025 | 01:54 PM
kanurys's Avatar
5 Year Member
What is the torque spec of the smaller castle nut?
Old Jan 24, 2025 | 02:33 PM
Melrose 4r's Avatar
5 Year Member
67 ft-lb per my 1986 Toyota truck and 4runner repair manual.
Old Jan 24, 2025 | 04:54 PM
kanurys's Avatar
5 Year Member
Thanks!
Old Jan 25, 2025 | 12:19 AM
Fugarrr's Avatar
Thank you for the info.
Viciousharp
Feb 17, 2016 10:24 AM
tikamonstr
Mar 13, 2011 08:39 PM
T4L
Apr 17, 2009 09:33 AM
Kyle95sr5
Dec 29, 2007 02:57 PM
metaland
Nov 4, 2005 08:09 AM
