Using the crank from a truck with more miles?
Old Oct 29, 2019 | 09:31 PM
Monkeynts's Avatar
I have a 22re with rod knock, dunno if it was a main bearing or a rod bearing or even a trust washer. Anyway the crank is chewed a little looks like metal got between each bearing on the crank.But I have a 22re in the back with 250000 miles on it. Would you just use the crank from that if the condition seemed good? Or would you turn the old one? The 22re I would be putting it in has 120000 miles which is why I'm trying to save the motor.
Old Oct 30, 2019 | 10:40 AM
old87yota's Avatar
I would use whichever crankshaft was in better shape.
Either way, I would want to visually inspect each one and then do some measurements to see if either crankshaft needs significant machining.
Innocent Fool
Sep 27, 2014 12:39 AM
YotaSnap
Aug 31, 2013 01:16 PM
branw97469
May 17, 2013 02:31 PM
DrCreosote
Jun 11, 2011 01:45 PM
PirateMcgee
Mar 18, 2010 01:22 PM
