Crank too tight to spin.
Old Aug 30, 2013 | 06:46 PM
YotaSnap's Avatar
I've read through many different threads on all of the common sites and cannot find out why I cant spin my crank.
Its far too tight to do anything.
The crank was said to have been turned .10 and I pulled a rod cap off and it was .25
That doesn't seem right to me, but I don't know about the measurements on these things anyhow.
I re torqued everything and still too tight.
What do I do?
Old Aug 30, 2013 | 06:55 PM
Kiroshu's Avatar
Sure its a crank shaft journal issue and not in the cylinders...?
Piston to cylinder wall clearance too tight...?
Corrosion...?
Incorrect bearing sizes installed...?
Engine taken apart..?
Assembly still together...? Top end restrictions...?
Old Aug 30, 2013 | 07:30 PM
YotaSnap's Avatar
What size bearings should be used on a crankshaft that has been turned .10 under?
Old Aug 30, 2013 | 09:08 PM
JonnyBoy's Avatar
.10 over. The crank and bearing together still have to equal the total diameter of the old crank and bearing combo. If your bearings state .25 oversized, you have the wrong bearings.
Old Aug 30, 2013 | 09:29 PM
YotaSnap's Avatar
Thank you JonnyBoy. I was almost certain that was the case and I've only been working on engine for a year. The nitwit who put this together said he had been working on these for years.
Old Aug 31, 2013 | 01:16 PM
YotaSnap's Avatar
The rods, pistons, main and rod caps were all installed incorrectly.
CHECK out EVERYTHING when you buy a new engine!
Bourbonblues
Dec 15, 2017 05:43 PM
PBRaddict#1
Sep 14, 2015 04:18 PM
Corvoid
Sep 14, 2015 10:10 AM
JHalcyonM
Sep 14, 2015 01:10 AM
anndel
Sep 10, 2015 08:50 AM
