Interior dome light replacement??
Old Nov 6, 2019 | 03:09 PM
forestechos's Avatar
Hey guys is there a replacement dome light that's easy to install ....maybe a clear cover with an led bulb?
Old Nov 6, 2019 | 08:33 PM
Co_94_PU's Avatar
Lack of details...
The standard led bulbs fit the bulb holder.
A clear cover I wouldn't recommend, the factory cover is designed to spread the light out and prevent hot spots..
The trucks have the same mounting position at the rear of the cab you'll find on a 4runner (between front and rear of the cabin) it's a good spot to add an extra lamp
Old Nov 6, 2019 | 09:01 PM
RAD4Runner's Avatar
https://www.superbrightleds.com/cat/festoon/
Site will help you pick what you need.
Old Nov 7, 2019 | 02:18 AM
1989 pickup, the existing dome light is attached to the rearview mirror. An led bulb shouldn't get hot right?
Old Nov 7, 2019 | 03:03 AM
Paul22RE's Avatar
5 Year Member
31mm is the size for my 92
Old Nov 7, 2019 | 06:12 AM
scope103's Avatar
These work well https://www.aliexpress.com/item/32812695346.html . If you can wait a few weeks to get them, you can't beat the price!
Old Nov 7, 2019 | 09:19 AM
RAD4Runner's Avatar
LED runs cooler than incandescent.
Old Nov 7, 2019 | 11:13 AM
keycw's Avatar
5 Year Member
I swapped a second gen 4runner dome lamp in with a little dremeling. the little knob broke off mine and the lamp base is NLA, the lenses are still available through Toyota
yotantn
Feb 25, 2018 06:55 AM
wiseguymmiv
Nov 13, 2015 08:56 AM
francr
7
Dec 27, 2005 09:57 PM
DavidA
May 24, 2005 08:25 AM
HaveBlue
25
Dec 17, 2003 06:46 AM
