Pre 84 Trucks 1st gen pickups
Dome light LED
Old Dec 2, 2017 | 05:31 AM
yotantn's Avatar
Dome light LED
has anyone found an LED to replace the dome light for our first generations? (the one with the mirror on it)?
I've bought some but the LEDs are like bat wings and won't let it sink in.
Old Feb 21, 2018 | 05:09 PM
Waterfreek's Avatar
Bump. I need the same.
Old Feb 21, 2018 | 07:56 PM
RAD4Runner's Avatar
If I remember correctly I had to remove a metal reflector from the stock dome light housing in order to make the replacement LED "with wings" fit. However, I still found that anemic so I added an LED strip.
If you don't want to install an LED strip, feel along the sheet metal strip where the stock dome light is and you may feel a second opening that is unused. It's pretty big; You can mount a separate light housing on that, and wire in parallel to stock dome light bulb OR install a separate switch for it. Tap power from positive side of existing dome light wiring. Be careful how much wiring sticks out from behind the new housing so it does not short against the roof.
Old Feb 22, 2018 | 04:06 AM
rickc5's Avatar
I attempted to fit an LED bulb that I had in my spares box, but with the heat sink, it was way too big to fit. I finally settled on a standard-type bulb I had removed from a previous vehicle, which turned out to be much brighter than the very dim original bulb. Sometimes you just can't pound 2 lbs. of sand down a 1 lb. rat hole.
Old Feb 22, 2018 | 10:41 AM
Waterfreek's Avatar
Thanks for the help rad. I have an 82 pickup, I think I will try what rick said. Thanks to both.
Old Feb 22, 2018 | 01:11 PM
RAD4Runner's Avatar
Old Feb 25, 2018 | 06:55 AM
medicmoose's Avatar
I got the 24 LED from LROR and it worked great and fit in the factory light location on the mirror.
http://www.lowrangeoffroad.com/toyot...nd-36-led.html
