Pre 84 Trucks 1st gen pickups
gear swap
Old Jan 5, 2010 | 09:38 AM
slisdexia's Avatar
gear swap
I know this has been covered probably a million times but I'm searching for the wrong things and I'm having difficulty finding what I want to find.
How hard is it to just swap gears yourself and do it correctly?
I put in my own Aussie Locker, I've been a mechanic for 12 years so I'm no stranger to a wrench, but what do you need to do, or what do I search for?
Old Jan 5, 2010 | 10:18 AM
4Crawler's Avatar
Gears:
- http://www.4x4wire.com/toyota/tech/gear_setup/
Similar locker install:
- http://www.4x4wire.com/toyota/tech/lockright_locker/
Old Jan 5, 2010 | 10:19 AM
phildelfino's Avatar
Go to;
www.gearinstalls.com
and see if you could do it.
Old Jan 8, 2010 | 01:45 PM
slisdexia's Avatar
cool. guess I'll have to get some paint and giver 'er a shot! Nothing teaches quite like experience.
Old Jan 9, 2010 | 03:27 PM
norcal crawler's Avatar
i need some advise on gear swap(new to forum)
hey sorry if im posting this in the wrong spot, i couldnt fin out how to make a new post lol. im building my truck up on a budget. i have a 87 toyota 4x4 sr5 22re ifs truck. procomp lift with springs all around. i want to put gears in my truck. im currently running 32s with stock gears. i can get my hands on 4:30 gears and have them installed for about 150 an axel. how much will this improve my truck? is it worth the 300? oh and i have a trutrac front locker that will be thrown in as well, i know that will help offroading significantly but my question really is about the difference with the gears. let me know what you think!
Old Jan 9, 2010 | 06:39 PM
Gov't Mule's Avatar
slisdexia,
I just did front and rear in my '82, swapped from stock to 4.88s and added an Aussie up front and spooled the rear. Honestly, it's not really that bad if you PREPARE and TAKE YOUR TIME. The right tools are a MUST (12ton press, some good 2 jaw long reach pullers, dial indicator w/ magnetic base, dial caliper, torque wrench, and a couple special tools you'll need to fab yourself, etc.)
ZUK's website ( http://www.gearinstalls.com/ ) mentioned above is GREAT...I read just about everything on that site before I started. The front took me 2 full days mostly due to the learning curve, installing the Aussie, running down tools, etc. The rear went a little faster...about a full day start to finish.
It can be done and like you said it's a great way to learn. I say GO FOR IT! Let me know if you have any questions that I can maybe answer. GOOD LUCK!
Old Jan 9, 2010 | 07:28 PM
fyreandwater's Avatar
Having done mine, I would suggest getting an extra sent of bearings and making some set up bearings
Old Aug 6, 2015 | 07:23 AM
opencountry's Avatar
Can someone give me advice on this my Gear paint check. It looks like the position from heel to toe is good but I would like it to more towards the root of the tooth. I have looked online for guide to adjust the contact depth and it seems there is conflicting guides. I read one guide that says you cannot adjust the depth contact. Anyway what are your opinions. I am thinking of trying to add .002 shim to the pinion currently it is at .094
coast
drive
Old Aug 8, 2015 | 05:54 PM
dropzone's Avatar
Fossilized
PM Zuk he is the guru at gearinstalls.com
Old Aug 11, 2015 | 08:05 AM
kawazx636's Avatar
What does your backlash look like now? Your backlash basically determines your tooth depth. If your backlash is within spec then you should leave it alone. If your backlash is too great then you would want to adjust it and with adjusting your backlash your tooth depth will be greater. Tightening the ring gear side adjusting nut and loosening the non-ring gear adjusting nut will decrease backlash and increase tooth depth.
But personally, if your backlash is good now, I would have no reservations about leaving it like it is pictured -that is a good paint pattern to me.
Old Aug 11, 2015 | 05:57 PM
Thanks for the suggestion, I looked at zuk's website and took many notes.
Old Aug 11, 2015 | 06:01 PM
I had a 10 backlash in those pictures. I tightened the backlash to 8 (no tighter than 7 and no more than 9.5 across multiple checks) and it did bring the contact towards the root of the tooth. The truck is all back together and on the road again. No sounds at all coming from the diffs, but the rear runs pretty warm when I get off the freeway.
Old Feb 25, 2018 | 11:49 AM
Brokenheart's Avatar
86 pickup differential swap
newby here. Recently acquired an 86 4x4 pickup with 22r and a five speed. I live in the country so the first thing I did was purchased some 16” wheels and 31” tires tor replace the 15s. I’ve read you can swap differentials from a 4 runner with 4.88 gears but I don’t know what years will swap or if the IFS is a difficult swap or will even fit.
any help is greatly appreciated
Old Feb 25, 2018 | 01:51 PM
muddpigg's Avatar
Links to gears should be posted above,
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
deepmarsh
Aug 6, 2015 03:44 AM
mengquis
Jul 13, 2015 10:39 AM
Jnkml
Jul 6, 2015 01:20 PM
