Rust in High Humidity
Old Oct 1, 2019 | 10:59 AM
parchisi's Avatar
I'm looking at moving to Shreveport, LA next year and am wondering what effect, if any, the higher humidity will have on my '85 pickup rusting any more than it is. So far it's life has been spent in Idaho, New Mexico, and West Texas (high heat but very little humidity). It's got some bed rust and surface rust on the underside but it is otherwise very solid. I'm not sure I'll have a garage in Shreveport and am wondering if this thing is going to start disintegrating once it experiences a few Ozark summers. Thanks!
Old Oct 1, 2019 | 12:02 PM
RJR's Avatar
RJR
Rust generally requires the combination of moisture and some kind of chemical activity enhancer (salt, etc.). In Idaho (as in Colorado) you probably had your share of road salt, but not much moisture, so rust wasn't much of a problem. In Louisiana, you'll have plenty of moisture, but little salt (unless right along the coast), so again I wouldn't expect much of a rust problem. (Shreveport is well away from the coast.)
I had an uncle who lived near Portland, Oregon, and generally kept his vehicles for 20+ years. Never a rust problem, even though they get 80 inches of rain/year there.
Where rust is really a problem is the upper midwest, and/or northeast, where the humidty is high and they use lots of road chemicals in the winter.
Old Oct 1, 2019 | 03:27 PM
parchisi's Avatar
Thanks for the input, that makes me feel a little better! I think I would have rather sold her than see her succumb to car cancer.
Old Oct 2, 2019 | 12:14 AM
ev13wt's Avatar
5 Year Member
I had that fear 20 years ago when I moved from the CA bay area to Germany.
Still looking "ok".
Old Oct 2, 2019 | 03:20 AM
keycw's Avatar
5 Year Member
i live in baton rouge. been here about 1.5 years now. keep it under some sort of covered car port and if possible on tope of something concrete to stop the moisture from coming up from the ground. theres not really any salt here. youll be fine.
Old Oct 2, 2019 | 12:20 PM
scope103's Avatar
You might want to get underneath it with your hose and clean it up well. You could have some remnants of Idaho salt (is that why the French Fries are so good?), which you don't want to "activate" with Louisiana moisture.
parchisi
Ozarks
Oct 1, 2019 10:52 AM
MYV84B
Jan 8, 2016 01:57 AM
Batsoff
10
Nov 22, 2008 06:56 PM
narou
Nov 21, 2008 11:18 PM
4runnerguy
Sep 20, 2007 06:40 PM
