4runner problem
Old Oct 9, 2019 | 10:07 AM
Marcsonier's Avatar
4runner problem
I have a toyota 4runner 1991 I changed the engine to place a 3.4 everything is fine for the engine starts and everything but its light side that it does not work .. my alternator does not charge, I have no break light, no cluster light, radio and fan does not work either I just miss it to be able to run the jeep does it happen to someone I'm not able to find the problem ... help please !!
Old Oct 9, 2019 | 11:54 AM
5 Fists's Avatar
All grounds in good shape, and cleaned down to bare, shiny metal on bare, shiny metal?
Old Oct 9, 2019 | 12:10 PM
Marcsonier's Avatar
yes I buy them all in new yesterday and i change them
Old Oct 9, 2019 | 02:07 PM
ev13wt's Avatar
5 Year Member
So you did an engine swap and some lights don't work.
Old Oct 9, 2019 | 02:34 PM
Co_94_PU's Avatar
You will need to dig into the wiring schematics a bit more. I don't have the 91 manual in front of me.
There will be a few switched power lines that come out of the ignition switch, that may or may not supply your alternator.
The driving lights should have constant power (they are switched ground circuits) so start at the lamp holder and work your way back along the signal until you find where the power is cut.
Old Oct 9, 2019 | 02:46 PM
Marcsonier's Avatar
yes, I apologize if I do not say the right words I do not speak much English .. so I change my engine 22re for a 3.4 I made everything but I get to the wiring and get stock there ..my light cluster does not work no radio no fan, no break light I change everything my ground well sanded and install I check all the relay all my fuse .. and there is also my alternator that does not charge .. it's been about a week that I search and try a lot of things but I do not find the problem
Old Oct 9, 2019 | 02:50 PM
Marcsonier's Avatar
ok thanks i will try that
Elmer J Fudd
Oct 20, 2011 07:22 AM
Al's Chop Shop
Jan 26, 2010 04:35 AM
4runnerguy
Oct 18, 2008 10:08 AM
riversair
Oct 13, 2008 07:17 PM
Juggalo
Oct 24, 2003 10:06 AM
