No idle-up when starting cold engine
Old Sep 21, 2019 | 05:07 AM
randyjohnson1's Avatar
Hi. I'm brand new to the forum. I have a 1989 pickup 4X4 with the 3vze and automatic transmission. It used to idle up when the engine is cold, but now it struggles a bit to start and doesn't idle up. It idles fine and starts easily when the engine is warm. I put in new plugs recently which helped with power and it has had the usual maintenance - oil changes, air cleaner, timing belt with water pump, fluids, etc. It's a great truck and has 158K miles. Any advice?
Old Sep 21, 2019 | 09:25 AM
RAD4Runner's Avatar
If it's temp related, I would eliminate doubt on the temp sender cleanliness and connections by cleaning the senders AND THEIR MOUNTING THREADS down to bare, shiny metal. That should be done every 30 years
Then check if the fuel pressure-up system and the vsv is working. We installed fuel pressure gage piggybacked on CSI on our 22R-E's to aid that: https://www.yotatech.com/forums/f199...l#post52312190
Old Sep 21, 2019 | 10:00 AM
Thanks! Regarding the temp senders, if my temp gauge is working, does that mean that the senders are working, or is that unrelated?
Old Sep 21, 2019 | 10:19 AM
RAD4Runner's Avatar
Originally Posted by randyjohnson1
...if my temp gauge is working, does that mean that the senders are working...
There are other temp sensors that send signal to ECU, to Cold-Start Injector, etc. Sorry, I don't know location on the 3.0.
Need to clean them all for free every 30 years
Old Sep 21, 2019 | 10:21 AM
Thanks again!!
Old Sep 21, 2019 | 10:34 AM
millball's Avatar
Likely that there are issues with the idle air valve on the throttle body.
Old Sep 22, 2019 | 08:48 AM
Co_94_PU's Avatar
All the temperature stuff is located right next to each other on the VZE, from what I recall its at the center rear on top of the engine. A great place to work if you have thick hands.
Old Sep 22, 2019 | 09:25 AM
RAD4Runner's Avatar
Most welcome, O.P.
Originally Posted by Co_94_PU
A... A great place to work if you have thick hands.
LOL! I have skinny hands, yet I'm glad I have a 22R-E. I saw how tight the the 3.0 is on Redeth's. I would not even think of working on it - LOL!
YotaPower
Oct 29, 2015 06:43 AM
Xiphos
Nov 29, 2010 09:53 AM
buckz6319
Aug 4, 2009 03:08 PM
Hugo
Apr 20, 2007 10:26 AM
Skydigger
Sep 8, 2002 03:46 PM
