cold engine troubles
Old Sep 8, 2002 | 12:16 PM
Skydigger's Avatar
Hey all,
Since the weather has recently chilled out a bit I'm having trouble when the engine is cold. The engine starts fine but if I put it in gear (automatic) the RPM goes right down and it stalls. If I let it warm up all the way it is ok all day.
Anyone have any ideas or suggestion on where to start troubleshooting?
Thanks,
Warren
Old Sep 8, 2002 | 12:36 PM
Krash's Avatar
Maybe in need of a tune up? I'm by no means an expert but thats where I would start.
Old Sep 8, 2002 | 12:41 PM
Skydigger's Avatar
tune - up
Thanks man. I would think that too if I hadn't just had it tuned up a couple of months ago. The mech. said he didn't have to do anything to it. Plugs were clean, it ran well etc...
My first thought was the cold-start injector but since it starts ok I'm not sure that's it. Could it be a "too-lean" mixture since it only stalls when put in gear and cold?
Regards,
Warren
Old Sep 8, 2002 | 01:18 PM
Krash's Avatar
I dunno maybe check your pcv valve? If I remember right those have something to do with idle.. I know on my mustang all I had to do is pull it out and shake it and if it made a rattling sound it was alright but I still replaced it... Now don't take this as the bible, cause I by no means am a mechanic, just offerin advise to what I would do.
Old Sep 8, 2002 | 02:50 PM
Yoda's Avatar
I would have the engine coolant temp sensor (for the computer) checked or changed.
Old Sep 8, 2002 | 03:46 PM
Skydigger's Avatar
coolant temp sensor
Thanks Yoda,
I'll check that out for sure. Any chance it's ignition coil related as well? FSM makes mention of it...
Warren
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
Jonny246
Jul 12, 2015 04:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
cyclist231
Jul 7, 2015 12:56 PM
