Cup Holder Removal
Old Sep 23, 2019 | 09:05 AM
lastcall's Avatar
Cup Holder Removal
1990 T4r 4x4 with auto trans
The original holder that is currently in the 4 runner use to have an S-shaped metal retainer securing the lower portion of the holder to the top. Over time the retainer occasionally fell out and eventually lost so I fabricated a replacement which did not last over time. I decided bout time to replace the holder but I have searched and have not been able to find a 'how to' thread, or article for my 1990 application and would appreciate comments or suggestions.
Old Sep 23, 2019 | 12:10 PM
Discombobulated's Avatar
Is this the assembly you are talking about?
Old Sep 23, 2019 | 02:01 PM
lastcall's Avatar
Sorry, my description was not clear, I only need the cup holder and after fiddling with it using a mini screw driver I noticed, with the tray pulled out, on the underside of the holder there is an elongated slot and by prying oh so slightly was able to remove the holder, once out I found on each side of the holder there is a 'dog eared' retainer that secures it to the track. Checked for a replacement and found a couple on Ebay ranging from $50 to $30 that looked similar but not clear from seller's photo? Possibly another option would be to fabricating a metal Z type retainer out of the desired diameter rod, or go my basic quick-fix back yard mechanic route by cutting a chain approx. 2 1/2", thread thru the center of the holder with a clip at each end, intend refining the end clips, it works??, if asked I will deny I came up with the idea.
Discombobulated, I thank you for responding to my question!!.
Old Sep 23, 2019 | 02:10 PM
I think I have the retainer at home, left for a few but I can check when I get home but are you just needing the two retainers?
Old Sep 23, 2019 | 02:15 PM
lastcall's Avatar
I can be mistaken but seem to recall there was only 1 retainer if U do come across one and able to post a pic I should be able to fabricate a replacement?
Old Sep 23, 2019 | 02:24 PM
If I have one I can mail it for cheap, soon as I get home I’ll let you know
Old Sep 23, 2019 | 02:36 PM
lastcall's Avatar
If U do am interested.
Old Sep 23, 2019 | 03:37 PM
I have two, were you just needing one or both? Either way PM me your address and I’ll throw them in an envelope and mail them, my lady mails at her work for free so no charge
Old Sep 23, 2019 | 03:48 PM
I do show two retainers in my cup holder.
nblackburn
Jun 4, 2017 06:52 AM
davefarr
Apr 16, 2009 06:50 AM
SunFox
Nov 19, 2006 10:56 AM
