Need Help!!! Please.
Old Jul 30, 2008 | 05:10 PM
xlr8r1991's Avatar
Exclamation Need Help!!! Please.
I am looking to possibly take on a new project and am not sure what exactly is involved. here is the deal. i currently have a 1994 2wd toyota pickup with the 22re. and as most of you know 2wd sucks. so a friend of mine has an '89 or newer (not positive on the year) 4x4 truck with a 22re and an extremely rough body. my plan was to do a complete body swap. is this easily doable? are the floors the same? because i understand i would have to cut for the transfer case range selector. i understand as long as they are both 5 speed, which they are, body lifts are the same. so is it the same body? thanks in advance, -Eric.
Old Jul 30, 2008 | 05:21 PM
wrnchplr's Avatar
I know the answer.....but I won't tell you
climb under the trucks and get out a tape measure I'm sure you will find your answer.
I have put a 88 runner body on a 85 truck frame with only a little mods. I know it can be done.
Old Jul 30, 2008 | 05:22 PM
just a 22re's Avatar
do they look the same? body wise? and just looking it up theres alot on here about that
Old Jul 30, 2008 | 06:11 PM
Jay351's Avatar
If they are both the same generation (89-95), are both the same body models (ex cab short box, etc.) Teverything will bolt up.
You will need to cut a bigger hole for the t-case shifter, and the 2wd front end and fenders are different. They will still bolt up though..
Old Jul 30, 2008 | 06:18 PM
DeathCougar's Avatar
Since you are trying to swap 2wd to 4wd, you may run into some minor issues with the sheet metal, lights, etc since the 2wd uses a completely different nose.
Old Jul 31, 2008 | 05:36 AM
xlr8r1991's Avatar
ok thanks, i know about the front ends, and the front fenders having larger openings to fit bigger wheels. and seeing that the bodylifts were the same for both trucks made me think that also. but thanks for all of your input. i will let you guys know how it works out.
JonG85
Jan 18, 2023 04:31 PM
tshort48
Sep 27, 2015 01:04 PM
ToyotaMD
Sep 22, 2015 04:49 AM
terminator
Aug 31, 2015 11:32 AM
bvleonov
Aug 22, 2015 11:39 PM
