Starting Problem/ Hot or cold??
Old Jul 29, 2008 | 04:30 PM
Yota4x494's Avatar
Angry Starting Problem/ Hot or cold??
I have a 94 Yota Pickup 4x4, great truck but have a problem with the starting. It will fire right up when it is cold, but after running to normal temp and i shut it off to run into the store and try to start it again it will not start, it will turn over and has enough battery charge, and is getting fuel, so i have narrowed it down to the ignition/starting. i have heard coils go bad and all that but looking for some other ways to test it, to find the real problem. It has 194,xxx miles on the body, so maybe something expensive it due to happen, i dont know! Any info would greatly be appreciated! Thanks!
Old Jul 29, 2008 | 09:51 PM
just a 22re's Avatar
motor?
Old Aug 1, 2008 | 07:56 PM
Yota4x494's Avatar
Sorry its 3.0 V6
Old Aug 1, 2008 | 09:04 PM
76ANTHONY's Avatar
check the manual sticky up top and download it theres a test in there for the coil, could be the issue
Old Aug 4, 2008 | 09:23 PM
Yota4x494's Avatar
The coil has spark, so that is good, we checked plugs, wires, and coils. We have found that the distributor gets really hot and may be causing it not to start when it gets too hot, i am going to check that then i dunno what else..
Old Aug 4, 2008 | 09:24 PM
ozziesironmanoffroad's Avatar
you said its cranking? if not, its probably the starter.
bigjstang
Jun 2, 2025 03:56 PM
BushPig
Oct 29, 2022 06:26 AM
Doug4320
Mar 24, 2018 10:11 PM
Avenged
Jul 9, 2015 07:55 AM
HRDC0R19
Jul 5, 2015 06:43 PM
