1993 4x4 pickup steering issues
Old Jul 27, 2008 | 09:11 PM
snowboardstudent's Avatar
I have a 93 4x4 3.0L that was hit on the driver's side front wheel while parked. Now when I drive the inner tie rod on that side rubs on the frame. I have replaced the inner and outer tie rods on that side, hoping busted joints would cause the rubbing. It still rubs. Any ideas? Nothing looks bent. Pitman arm or relay rod? What should I try first? Thanks
Old Jul 27, 2008 | 10:59 PM
DeathCougar's Avatar
Bent frame. Its pushed the control arm back so the steering arms are touching the frame.
Old Jul 28, 2008 | 05:34 PM
Thanks for the reply. This is possible but the impact to the wheel seems very light. The wheels were pointed straight when I left the truck, I come back and they are pointed to the left. No wheel, body or tire damage. Just the original concerns listed above. Could a low speed impact do such damage?
Old Aug 7, 2008 | 06:58 PM
Turns out it was a bent relay rod. Covered under relay rod recall....
Old Aug 7, 2008 | 09:06 PM
zlathim's Avatar
I'll take "Worse Case Scenario" for $500 Alec.
Old Aug 7, 2008 | 09:32 PM
Lol helps when these guys give us ALL the info
Old Aug 7, 2008 | 09:48 PM
thook's Avatar
I think the latest info was not known until after the fact. Your call was a good guess, though. That's what I would have thought, too.
Weidle
Jan 21, 2019 05:39 AM
voiddweller
19
May 2, 2016 09:10 PM
Valvoman
Jun 28, 2015 02:45 PM
Dylan199119
Jun 25, 2015 09:54 PM
