auto trans to manual trans???
Old Jul 29, 2008 | 06:56 PM
yotaman804's Avatar
Cool auto trans to manual trans???
I have been kicking around the idea of swapping my auto trans out to a manual. How hard is it? And does anybody know around how much it would cost? I would only buy used parts from say a pick and pull.
Thanks
94 Toyota 4runner V6
Old Jul 29, 2008 | 07:19 PM
fillsrunner4's Avatar
Hardest part is making it work with the ECU. I havent looked into that part much but as far as the swap parts...
Youll need a new or used tranny R150F for a V6 or R151F with use of the R150f bellhousing (R151F has a bit lower gearing)
You can get the clutch parts all from marlin crawler and all you have to do after that is put in the pedal assy. from a 4runner or truck for that matter and plum the lines.
Its real easy to put one in but I just dont know what the mod is to make it work with the Auto ECU
Old Jul 29, 2008 | 07:22 PM
yotaman804's Avatar
would buying a harness off of a 4runner with a man trans fix that?
Old Jul 29, 2008 | 07:30 PM
kinda but youd need to swap ECU's also to do that and then also.
There is a way to make the Auto ECU work for this. My understanding is that you have to trick the ECU to think the the truck is in neutral.
Search a bit more I know this topic has been covered. the actual swap is easy its just the wiring portion I havent dug into
Old Jul 29, 2008 | 07:33 PM
yotaman804's Avatar
k thanks and u probably know gearing pretty well, well i just put 32 11 1/2 bfg mudd terrains on and i've heard that i should change the gearing is that really necesarry? the stock tires were 31 inch
Old Jul 29, 2008 | 07:42 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
I know my 91 auto 4runner with stock 31's come with 4.56 gears.....
Old Jul 29, 2008 | 07:43 PM
could go to 4.88 but I would hold off till you go bigger tires than 32's. 33's yeah and bigger its really going to help you. You dont have to but it would hurt to.
Old Jul 29, 2008 | 07:45 PM
yotaman804's Avatar
kk well i'm plannin on getting the transmission figured out. just wondering though how much total do u think it was for the sas swap? and if your not like a mechanic should u not even try to do it by urself?
Old Jul 29, 2008 | 07:51 PM
Im still working on mine so cost wise the cost is endless IMO
Check out my build and others and youll see whats all involved.
Of course I think everyone should do there own work but thats not always possible. For this type of work though I would always suggest even if you dont have the skills now... Learn it and DIY Youll be much happier in the end.
Good luck and search more cause youll find all the answers here and on the web
Old Jul 29, 2008 | 08:09 PM
shancerlelby's Avatar
heres a good thread on the how to including wiring
https://www.yotatech.com/forums/f116...mplete-126323/
i've been thinking of doing this to my rig next. but auto is so much nicer for wheeling :/
Old Jul 29, 2008 | 08:11 PM
yotaman804's Avatar
k thanks guys for the help
Old Jul 29, 2008 | 08:42 PM
myyota's Avatar
You shouldn`t have to change the computer or the wiring harness. I know that when my 86 4Runner was swapped from auto to manual all that was done to the wiring was to unplug the transmission computer and bypass the neutral saftey switch, and everything else worked fine.
Old Jul 29, 2008 | 08:50 PM
yotaman804's Avatar
any ideas how much the whole thing should cost condsidering i'm buying used parts?
Old Jul 29, 2008 | 10:23 PM
Price varies everywere! Parts from marlin under 100 and new tranny from $100 to rebuilt Go here http://www.marlincrawler.com/htm/tra...ansmission.htm
Everything you will need for the swap just about is here.
I like that comment myyota. Makes sence tat that could be how. If thats hows its done, its pretty simple!
Old Jul 30, 2008 | 07:47 AM
yotaman804's Avatar
alright i'll look i was looking at ur pics though fillsrunner 4 and i saw u had crawling gears if i'm doing a trans swap would it be easy to do that too along with the swap or is that something i can do anytime?
Old Jul 30, 2008 | 11:05 AM
Anytime
If you can afford it why not do it
Old Jul 30, 2008 | 12:09 PM
SLOWBOOST's Avatar
heres my thread too for some more help.
https://www.yotatech.com/forums/f116...riteup-146085/
Old Jul 30, 2008 | 12:30 PM
76ANTHONY's Avatar
VERY INTERESTING, i may wanna look into this, then my wife wont take the 4runner any more
Old Jul 30, 2008 | 12:54 PM
Jay351's Avatar
Having a 5sp weeds out alot of idiots from driving your rig... Its great!
Old Jul 30, 2008 | 07:52 PM
yotaman804's Avatar
haha i like the idea of keeping the wife and idiots away from my car!
