Yellow radio wire problem
Old Aug 1, 2008 | 05:43 AM
4xJedi's Avatar
Hey all. Installing a CB in my 86 4Runner I first tried tapping into my yellow wire to the Kenwood. It's constant on and is suppose to be power for the radio's memory (IIRC). Anyway it worked fine when I tested everything then re-assembled the dash, rechecked and no power on radio or CB. Some wires must have moved during the re-assembly. I still have power from the red 'key-on' wire to the radio but the yellow is dead. I traced back to the harness plug and still dead. All the fuses in the kick panel and under the hood look good. I'm also running an aftermarket amp and those fuses are fine. I have a crappy Haynes manual and the wiring diagram doesn't show me what I need. Any ideas? Thanks.
Old Aug 1, 2008 | 07:22 AM
4xJedi's Avatar
Turned out the factory single blue wire w/yellow stripe came unplugged. Not sure how the factory clip came loose but it was hiding under the other wires. Anyway, all fixed.
Once again my Toyota didn't let me down, it was something I did.
Old Aug 1, 2008 | 07:49 AM
wjwerdna's Avatar
yay you fixed it yourself in an hour
Old Aug 1, 2008 | 08:00 AM
4xJedi's Avatar
That's how I roll .
Old Aug 1, 2008 | 11:22 AM
just a 22re's Avatar
wooooowhooo good job!
MO transplant
Apr 23, 2023 11:58 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
steve miller
Oct 10, 2015 01:40 AM
toyota32
Jul 6, 2015 05:42 PM
colinmil
Jul 6, 2015 04:03 PM
