No 1 air hose
Old Jul 27, 2008 | 01:47 PM
roXefeller's Avatar
No 1 air hose
Trying to pull the no. 1 air hose off the reed valve to get under the air intake chamber. There is so little space, its tough to break the hose loose. Anybody had trouble getting this loose? The hose runs vertically behind the reed valve before curving towards driver side and going under the chamber.
Old Jul 27, 2008 | 01:56 PM
76ANTHONY's Avatar
sometimes it take a little persuation
Old Jul 27, 2008 | 01:57 PM
corax's Avatar
year, model, engine? I thought reed valves were only used in 2 stroke engines . . . is there another name for it?
Old Jul 27, 2008 | 01:59 PM
abecedarian's Avatar
@corax- AIR valve. the reed valve is part of the air injection reaction system- the efi equivalent of the air pump used on carb'd engines. uses pulses in the exhaust and intake systems to inject clean air into the exhaust to help the catalytic converter.
Old Jul 27, 2008 | 02:19 PM
Cyberman's Avatar
I used a mini pry bar to get it loose and off. Definitely not enough space in there for hands.
Old Jul 27, 2008 | 03:44 PM
just a 22re's Avatar
how about a picture of this thingy cause yeah i have no idea what your talking about!!!! and i rebuilt my 22re so if its on there ive done it by hand!
Old Jul 27, 2008 | 03:50 PM
allan- you know that big toilet bowl looking thing under the throttle body? follow the hose down and under the intake to where it goes.
Old Jul 27, 2008 | 04:30 PM
scope103's Avatar
The only way I was able to get the PAIR hose off was to lift the plenum as far as I could (which isn't too far; that's why you're trying to remove the PAIR hose in the first place!), then remove the bolts holding the metal piping that lies beneath the plenum. With a little bit of jiggling, you can remove the plenum and leave the piping behind. Then there is enough room to get to the PAIR hose.
The problem isn't just lack of space, it's lack of leverage. You can barely get your hand in there, and once you do you don't have anything to push against.
Good luck!
Old Jul 27, 2008 | 05:22 PM
corax's Avatar
OK I think I know what your talking about now. yeah that hose is usually stuck on pretty good. with the clamp off try twisting the hose back and forth, or you can slid a small screwdriver between the hose and nipple to loosen it up
Old Jul 27, 2008 | 07:00 PM
roXefeller's Avatar
No 1 Air hose
Its a 94 V6 (3VZE).
Thanks for the replies. Yup, no room for much. Ever considered removing the hood for more room? I've tried the screwdriver trick. Thats my SOP for breaking other hoses free. There just isn't much room, even for a keychain screwdriver. I'll probably give the mini pry a try. What did you leverage that against? I've tried similar attempts already, so I'll probably end up unbolting the tube thats beneath the plenum. How many bolts are there? Ever considered removing the entire reed valve and VSV, if that will even solve the problem. The FSM doesn't give any detail for doing so.
Old Jul 27, 2008 | 07:10 PM
well now I'm going off over into the other corner to do 'over in the corner things'. I don't have a V6 to look at and deal with so now my time (what little it actually was to begin with) has been wasted. I'm fairly confident that the V6 has similar components to the 22RE, but that would've been nice to know when you first asked for help.
Old Jul 27, 2008 | 07:30 PM
ah that thing! ok you use a 90° needle nose and go from under the truck up then you just pull the band back and then grab the hose itself and wiggle it off the side thats on the bowl you can just take that of by hand i did
Old Jul 28, 2008 | 04:26 AM
Cyberman's Avatar
You can't come up from under the truck to get to that on a 3.0. I can't remember what I used for leverage. I know that I did stick the mini pry bar underneath the hose and went around between it and the valve to try to free it up some.
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
bighaydn
Aug 4, 2015 07:17 PM
gmonnie123
Jul 26, 2015 02:44 PM
skoti89
Jul 8, 2015 12:05 AM
