Just replaced knock sensor and now truck wont start PLZ Help
I just replaced the knock sensor wire and now my truck wont start.. i adjusted the timing to see if anything, but nothing, so i checked for spark on the plugs and that went good... im out of ideas as of right now,,,, im in need of some quick help..
iirc, the knock sensor wire is a shielded wire, meaning there is a center conductor surrounded by an insulating core and a grounded, woven shield. make sure the center and shield are not shorting out.
i took off the timing cover and noticed that the marks on the cam sprocket werent aligned right.. would that be a good cause to the problem, and also when i was trying to start it, i unplug the knock sensor from the wiring harness and still no fire
voiddweller
19
05-02-2016 09:10 PM
jmc88runner
06-18-2015 03:39 PM
