Just replaced knock sensor and now truck wont start PLZ Help
Old Jul 25, 2008 | 11:59 AM
4RrunnerJ's Avatar
I just replaced the knock sensor wire and now my truck wont start.. i adjusted the timing to see if anything, but nothing, so i checked for spark on the plugs and that went good... im out of ideas as of right now,,,, im in need of some quick help..
Old Jul 25, 2008 | 03:16 PM
Cyberman's Avatar
All the hoses on correctly (esp. fuel lines)?
Check your fuses (esp. EFI)?
Old Jul 25, 2008 | 03:29 PM
abecedarian's Avatar
iirc, the knock sensor wire is a shielded wire, meaning there is a center conductor surrounded by an insulating core and a grounded, woven shield. make sure the center and shield are not shorting out.
Old Jul 26, 2008 | 11:46 AM
4RrunnerJ's Avatar
i cheked the fuel line and i jumped the wires for the fuel pump and everything went good... I also did check the fuses and they were good to
Old Jul 26, 2008 | 11:56 AM
4RrunnerJ's Avatar
how would i check for that, or is there even a way....
Old Jul 26, 2008 | 11:58 AM
4RrunnerJ's Avatar
i took off the timing cover and noticed that the marks on the cam sprocket werent aligned right.. would that be a good cause to the problem, and also when i was trying to start it, i unplug the knock sensor from the wiring harness and still no fire
naward1996
Apr 23, 2018 05:23 PM
voiddweller
19
May 2, 2016 09:10 PM
Bru
Jun 23, 2015 06:58 PM
jmc88runner
Jun 18, 2015 03:39 PM
bobbybouche
Jun 18, 2015 10:22 AM
