Replaced clutch now it won't release
Old Jul 23, 2008 | 04:22 PM
Marcot1's Avatar
I replaced my clutch in my runner this last week and finally got everything back together. I thought everything was okay putting it back together but I was wrong. The first sign of trouble was when I started the truck in neutral (transfer case and tranny in neutral) and I was unable to put it in gear.
The clutch pedal felt like it had pressure, not it's normal amount but it did not drop straight to the floor. I had my wife hit the clutch pedal while I was looking at the slave cylinder, it was actuating the piston a good inch or so.
After some more tinkering and pressing the clutch pedal down it got progressively weaker (less force to press) until there is almost no resistance to push it straight to the floor (it returns to it's normal resting position quickly.
I did not have any trouble with the hydraulics before changing the clutch nor did I disconnect any of the lines while changing the clutch out.
Did I screw up the install? This was not my first clutch, just the first one in a 4x4 truck as opposed to a fwd car. I am pretty sure I torqued everything to speck from the 93 FSM that is floating around on the net.
I'm going to replace my master cylinder tonight with an OEM replacement and see if that helps the situation.
If it is not the master cylinder (or the hydraulics) what could it be? Could it be I over torqued the pressure plate and it will not release no matter how much pressure is applied by the throwout bearing?
Any help is appreciated.
Things replaced:
Pilot bearing, clutch disc, pressure plate, throwout bearing, flywheel resurfaced (by a reputable shop).
Old Jul 23, 2008 | 04:24 PM
abecedarian's Avatar
1 word-
bleed
then a few more words-
if bleeding doesn't solve the problem:
my preference is to replace the clutch slave and master cylinders whenever the clutch disc and pressure plate are replaced.
Old Jul 23, 2008 | 04:29 PM
apalmer1's Avatar
yeah bleed it out well, it could simply be that the old pressure plate was weak and didnt take much force to disengauge and now that there is a new stiff one in there the hydraulics cant handle it, so bleed them in case there is any air, and then replace them if that doesnt solve the problem. Did you go with an OE or like OE replacement clutch? i put a centerforce clutch in my tacoma and replaced all hydraulics and everything and still was not able to release the pressure plate, those idiots designed it to require so much force to release the slave cyl wasnt even rated for it lol.
Old Jul 23, 2008 | 04:38 PM
TORTIS's Avatar
you did get the disc in the right way? they usually have flywheel side marked on them.
Old Jul 24, 2008 | 07:52 AM
Marcot1's Avatar
Thanks for the replys, I'm going to replace the MC and slave when I get home from work tonight and see how it goes.
I did make sure I put the clutch disc in the right way, that was one of the things I triple checked before mounting the pressure plate.
Old Jul 24, 2008 | 07:57 AM
just a 22re's Avatar
yes what they said toyota parts have a mind of there own they like to learn about what there doing as in you old clutch worked good new one not so good blead it out and it should be ok i not do both master and slave as a pair if you got the disk in right then there should be nothing wrong with that
check under the dash to make sure you didnt crack the peddles the clutch bracket likes to crack
Old Jul 24, 2008 | 08:42 AM
TNRabbit's Avatar
If you were getting an inch of actuation on the slave, it should have released the clutch.
Old Jul 25, 2008 | 08:29 AM
Marcot1's Avatar
I found out my slave cylinder had pushed the piston out of the housing at some point in time. It came apart in my hands once I pulled the two bolts off holding it to the tranny. I'm hoping this cause of my problems with the clutch not releasing.
I've got the parts in but I did not have time to finish the bleeding the system last night. I'll get to that this afternoon hopefully.
Thanks for all the help.
Old Jul 29, 2008 | 08:20 AM
Marcot1's Avatar
Thanks for all the help, it turns out it was the slave/master cylinders needed to be replaced. Everything seems to be working properly now.
Old Jul 29, 2008 | 09:27 AM
TNRabbit's Avatar
9 times out of ten it's an improper bleed job or bad master/slave. Glad you got it fixed!
sandyota
Feb 4, 2021 11:16 AM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
