Anoyying rattlig noise.
Old Jul 31, 2008 | 11:05 AM
TomkiRider's Avatar
what is this and would it be the cause for a rattling noise since it appears to be loose. its like that even on perfectly level garage floor
Old Jul 31, 2008 | 11:11 AM
Jay351's Avatar
The arrow is pointing towards your cam bolt. That holds the lower control arm to the drop bracket on from your lift kit.
Make sure its not loose! It looks like your suspension is flexed, are you on level ground?
Old Jul 31, 2008 | 11:12 AM
TomkiRider's Avatar
hang on leme go park it in the garage so its level and ill take a pic.
Old Jul 31, 2008 | 11:29 AM
TomkiRider's Avatar
Old Jul 31, 2008 | 11:30 AM
TomkiRider's Avatar
i put a flourescent under there for better light
Old Jul 31, 2008 | 04:38 PM
just a 22re's Avatar
um take a picture of your troson bar i think its broke cause that is not right does it bounce when you hit a bump? how bad is the ride on it
man that dont look good at all!
Old Jul 31, 2008 | 04:44 PM
Jay351's Avatar
Theres defantly something wrong with your drivers side. The A-arms should be at an equal angle. Level or farther down then the lowest drop bracket.
Jack up the drivers side, see if the torsion bar is broken!
Old Jul 31, 2008 | 04:46 PM
DeathCougar's Avatar
It looks like the LCA mount is majorly bent up! You certainly seem to have some problems there...
Old Jul 31, 2008 | 04:48 PM
get a picture of the whole front end just like what you did that way we can see both side and try and pin point where the problem is for ya
Old Jul 31, 2008 | 07:09 PM
TomkiRider's Avatar
k so jack up the frotn end and the torsion bars are where? a pic would help
Old Jul 31, 2008 | 07:13 PM
its a rod thingy that goes from the upper arm that the wheel is bolted to and from there it goes to right under your drivers seat and bolts to the frame there check and see if it goes all the way from the arm to the frame or if it ripped out of the frame
Old Jul 31, 2008 | 07:40 PM
TomkiRider's Avatar
torsion bar?
if so, it seems to be secure on both ends, same with the other side
Old Jul 31, 2008 | 08:14 PM
TomkiRider's Avatar
kinda would like to get this figured out 2nite...bump
Old Jul 31, 2008 | 08:27 PM
it could have striped out the end did you hit anything hard at all? where you live? milwaukee anywhere? cause if you do after i get my other amount of tattoos ill come over and help you out if you do
Old Jul 31, 2008 | 08:43 PM
TomkiRider's Avatar
nor cal lol, little far from milwauke. see the coutny fairs next week, im seelin some livestock and after that im SASn. i just HATE the rattling noise and dates kinda suck with a clanging over every bump to lol
Old Jul 31, 2008 | 09:09 PM
the clanging is the lest of your worries buddy you need to get that front end fixed asap! mine does the rattle to i dont care its a truck i mean come on you buy a truck to be used as a truck if you dont then why right? if you buy a truck and drive it like a car the trade it in no need for it!
Old Jul 31, 2008 | 09:29 PM
TomkiRider's Avatar
no i mean this is a clanging like that jus lttle while ago and it soudns like somethins definaltey not right. i know its sounds like im bein lazy but if theres no cheap fix for it, im nto gonna bother since im startin on SAS in a little more than a week. 1 of my friends works at the yota shop in town, maybe ill take it to him on one of his days of and he can look at
zytra
Jan 24, 2019 03:16 PM
BK2TFUTURE
Oct 11, 2015 08:42 PM
YotaPagota
Sep 20, 2015 06:24 PM
langry345
Sep 14, 2015 03:36 PM
Streetrod19772000
Sep 10, 2015 06:22 PM
