manual hubs
Old Jul 23, 2008 | 07:12 PM
tman12345's Avatar
manual hubs
What would be a good price for a set of manual hubs from a junkyard?
Old Jul 23, 2008 | 07:14 PM
bigt's Avatar
a good price 25-50 bucks
Old Jul 23, 2008 | 07:15 PM
TOYOTA 1's Avatar
x2.. sounds about right.
Old Jul 24, 2008 | 04:24 AM
dirtoyboy's Avatar
I am assuming you are talking about IFS lock hubs...yea I wouldnt pay over 50 bucks for a decent rebuildable set.... 25 would be a good deal
Old Jul 24, 2008 | 12:17 PM
Jay351's Avatar
Around my parts they go for about 75 bucks...
Old Jul 24, 2008 | 02:22 PM
tman12345's Avatar
alright thanks guys
Old Jul 24, 2008 | 04:50 PM
tman12345's Avatar
How hard will they be to get off the vehicle at the junkyard? what tools will I need to take them off? IS it just an unbolt ADD and bolt on manual hubs thing or is there more involved?
Old Jul 24, 2008 | 05:03 PM
Jay351's Avatar
Things you will need:
PB blaster or similar penetrent lube
Brass hammar and brass drift
10mm and 12mm sockets (I think, bring a socket kit to be safe)
Small extension to clear the hub body
To remove:
-Remove 6 12mm bolts holding the hub dial on, make sure its set to FREE
-Remove hub cap
-loosen but dont remove the 6 12mm nuts holding the hub body onto the truck.
- Spray all the cone washers with pb blaster, wait
- Using a brass drift on the side of the hub body, give it a good smack near each stud, this should release the cone washers. Carefull, they tend to come SHOOTING out, hence why you left the nuts on in the first place
- Remove gold 10mm bolt and washer
- Remove hub body.
Install is reverse of removal. Just need to remove the ADD plate which is almost exactly the same as removing the manual hub.
Make sure they are "aisin" hubs. Warns require a kit..
Old Jul 24, 2008 | 05:05 PM
904_runner's Avatar
My warns went on with just the hub
Old Jul 24, 2008 | 05:11 PM
bigt's Avatar
bring a propane torch heat up the studs then hit the side of the hub and the cone washer will fly out like pop corn takes NO TIME LIKE THIS!!!
carlspeed
Aug 23, 2015 02:59 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
