Temp too cool?
Old Mar 12, 2007 | 07:34 PM
SC2WD's Avatar
Cool Temp too cool?
I have a new (to me) '94 2wd 22re all stock. The temp never goes hotter than about 1 needle width above the bottom line--maybe two at best. My buddy who has a 4 runner says it should sit in the middle of the guage. The heater seems to work fine (I don't know how hot its SUPPOSED to be, but it keeps me warm) and everything else seems fine. Is the termostat stuck?
Thanks!
Old Mar 13, 2007 | 09:39 AM
SC2WD's Avatar
Anyone?
Old Mar 13, 2007 | 09:41 AM
Ringmaster's Avatar
Yep a good starting place would be to replace the stat.
Old Mar 16, 2007 | 11:09 PM
toytruckbmerbike's Avatar
Hey man is your timing "retarted" a tooth or two I'd check to see if where the rotor button is pointing when it is at top dead center
Old Mar 17, 2007 | 12:30 AM
the_supernerd's Avatar
It sounds like it is either the thermostat or the guage. Put in the thermostat and if it still does not get warm then it is the guage, the sending unit, or a wiring problem.
Take out the thermostat and see if it is stuck or has holes drilled in it. If you do not know the history of the thermostat then it is a good idea to put a new one in. If it ever gets stuck shut then the engine will overheat. A genuine Toyota thermostat has a rubber seal on the valve and they work better. Flush the coolant while it is out if it has not been flushed recently.
Since the thermostat will be out, put a garden hose in the thermostat hole and take off the lower radiator hose and flush until the water coming out is clear. I would recommend Toyota red antifreeze when you refill it, but it is not necessary.
Old Mar 17, 2007 | 03:09 AM
foot0069's Avatar
Read the section on tstats before you buy a new one. The flush is a great idea.
Jim
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Old Mar 17, 2007 | 03:24 AM
TOYZILLA's Avatar
low temp.
He didnt say he had no power!The temp is reading low. So it's either a bad temp guage or no/stuck open thermostat. Replacing the thermostat would be a good starting point
Old Mar 17, 2007 | 04:06 PM
SC2WD's Avatar
Thanks all. I appreciate the advice and I don't know anything about the service history so I assume it could use a flush anyway. It seems to run well so is there any negative consequence to having it run cool? Is it affecting my air/fuel mixture (running too rich)? The rad hoses are warm... If it isn't hurting anything, it seems like it would be better to keep it cool....? Any thoughts?
Old Mar 17, 2007 | 04:36 PM
86toysr5's Avatar
my motor use to do that in my 82 and then while it was in my 86 but in this 86 it stays in the middle
Old Mar 17, 2007 | 07:24 PM
crackerjack's Avatar
MIne is doing the same thing, put in new Tstat and needle went more to the left? I guess I'll take the sending unit out and see how it works maybe you could put it in a pot of hot water that has a cooking temp guage ? I'll let you know if I find out anything
Old Mar 17, 2007 | 08:32 PM
TOYZILLA's Avatar
running cool
yes it could be bad not to fix. what if the t-stat is stuck open now, then it gets stuck closed an over heats. You should find the prob now before it cost $$$ a new t-stat is cheap under $10 at most an several hundred $$$ if she ever over heats.
Old Mar 18, 2007 | 01:48 PM
SC2WD's Avatar
Thanks again for the replies. Keep em coming? Any other negatives besides the possibility of it getting stuck shut?
Old Mar 18, 2007 | 02:06 PM
Your engine is designed to operate at a specific temperature. Some of the smog controls will not operate at lower temperatures and the fuel/air mixture is going to be off. The engine needs to be at the normal temperature for everything to work best.
Old Mar 27, 2007 | 09:41 PM
SC2WD's Avatar
Replaced the t-stat. I asked for the dual stage and the dealer gave me the normal stock one. I tested them both (old and new) in a pot of water and the old one opened earlier and then didn't close all the way when cooling. Put the new one in in 10 minutes and the temp. seems perfect now. Haven't had a chance to get a flush yet but I need to. I was thinking I might improve my MPG with a new t-stat but the first tank didn't show any improvement (I drove to Tahoe though, so I'm sure that affected things).
Thanks for the help.
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
bradahman
Oct 1, 2015 09:24 AM
Matthew Perez
Sep 28, 2015 05:43 PM
rmill05
Sep 27, 2015 01:43 PM
