Emissions Failure at Idle
Old Mar 11, 2007 | 08:08 PM
Fergie's Avatar
I've got an '86 Turbo 4x4 that passed emissions once, but has failed most recently, too many hydrocarbons at idle.
To get it to pass, here is what I'm looking to do:
Clean the MAF
Check/replace plugs
Replace O2 sensor
Replace PCV valve(broken)
Fix cracks in intake rubber
Replace fuel filter.
What else should I look to fix before I take it back in for re-testing?
Thanks
Fergie
PS-Seafoam treatment was done a week before the emissions test failure.
Old Mar 11, 2007 | 11:30 PM
Crymson's Avatar
Clean/replace your air filter as well and you should pass with flying colors. If you don't pass after replacing/fixing all of the components you listed, there are a few tricks you can do to lean out your engine, but it really shouldn't come to that.
Old Mar 12, 2007 | 10:45 AM
Fergie's Avatar
Hope not.
I'll get going on this stuff this week, and hoepfully it wokrs.
I was only over by a small amount, less than 20, so it should be too hard to get the vehicle back in to compliance.
Old Mar 25, 2007 | 04:49 PM
Fergie's Avatar
Good news...I passed with everything I did above.
Old Mar 25, 2007 | 07:23 PM
Lysmachia's Avatar
Saweet! Good checklist too... I'll have to do all that next year when I re-do my emissions...
Old Mar 26, 2007 | 08:10 AM
Fergie's Avatar
A caution to all the Seafoamers too:
DO NOT GO TO EMISSIONS UNLESS YOU CHANGE YOUR PLUGS AND O2 SENSOR AFTER A SEAFOAM TREATMENT.
When you do change your plugs and sensor out, save them, and use them for seafoam treatments. The extra time onvolved will offset new plugs and a new sensor.
The intake tube for the RTE is $40 and only available through Toyota. Use black RTV to seal any cracks you have, and you will be fine.
Also, when changing your fuel filter, take the tire off, and remove the access panel, and the entire process is cake.
Blamalam
Mar 12, 2022 07:34 AM
montanatruck
Feb 26, 2017 07:07 AM
GrimWolf
Aug 28, 2015 03:36 AM
utahman
Aug 23, 2015 02:04 PM
Sarcazmo
Aug 15, 2015 08:22 PM
