FUEL pump. Location?
Old Mar 14, 2007 | 07:19 PM
keithguts's Avatar
Can anyone tell me where the fuel pump is located in a 1988 22re truck.
Old Mar 14, 2007 | 07:26 PM
Ringmaster's Avatar
Fuel tank.
Old Mar 14, 2007 | 07:30 PM
keithguts's Avatar
Originally Posted by Ringmaster
Fuel tank.
OK this is the problem. It is not my truck I'm finding out info for a friend. I don't think it is getting gass, and this is what makes me think it is the fuel pump. I also took off the hose from the fuel filter and cranked the rig, and nothing comes out fo the fuel line. If I speay starter fluid into the T. Body, it starts up and runs for about 20 sec. and then dies. What else would keep gass from getting to the filter other then the fuel pump. any help please!!
Old Mar 14, 2007 | 07:34 PM
Ringmaster's Avatar
Fuse's
Old Mar 14, 2007 | 07:41 PM
CyMoN's Avatar
http://www.4x4wire.com/forums/showfl...5&o=14&fpart=1
Old Mar 14, 2007 | 09:10 PM
^VooDoo^'s Avatar
Jump the B+ and the FP at the test point, Not sure where the 88 is but 89 up shows them all mounted to the side of the enginebay fusebox.
Turn the key to run and the pump should run, If not, Bad pump or intank wires.
If it runs only when power jumped then the EFI fuse, EFI relay, OpenCircuitRelay or the AFM Fuelpumpswitch has a problem.
Old Mar 15, 2007 | 07:16 AM
MMA_Alex's Avatar
EFI fuse is definately the first thing to check. If the efi fuse is good you can jump the terminals listed above and the fuel pump should run. You can then trace the wires to the pump and check for voltage. The pump itself is in the top of the tank, and I think you have to drop the tank to get at it, but I remember reading somewhere that certain trucks (ext cabs maybe?) have an access port in the back corner of the cab that you can take out to get at the pump
Doug4320
Mar 24, 2018 10:11 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
jetspeedz
Jul 13, 2015 09:32 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
