Spark Plugs
Old Mar 11, 2007 | 09:10 AM
JEBSR5's Avatar
Spark Plugs
Time to put new plugs in, been thinking about maybe trying the new NGK Iridiums. Noticed it says requires less voltage to get same or better spark, which should be good for the weak system as is.
Are the Iridiums overkill? Worth it at $6.95? Looks like above may be an advantage.
Old Mar 11, 2007 | 09:19 AM
slosurfer's Avatar
I am installing some today, so I guess I will see if they were worth it.
Old Mar 11, 2007 | 09:40 AM
TNRabbit's Avatar
There is no intrinsic difference in plugs other than the longevity. I have the Denso Iridium plugs; they work fine, no real difference than the Yota plugs I had before. I expect to see 100k out of them, though.
Old Mar 11, 2007 | 10:48 AM
MudHippy's Avatar
Not overkill. If what they claim is true, that's a good thing, and can't hurt nothin'.
Old Mar 11, 2007 | 10:47 PM
notanymore's Avatar
as far as i know they just last alot longer than regular plugs do
Old Mar 12, 2007 | 05:15 AM
Brenjen's Avatar
I just put the NGK iridium IX plugs in mine on Friday & the truck runs fine with them. I adjusted the timing from 0-t.d.c. to 10-b.t.d.c. at the same time so it's hard to say how they affected the performance. I didn't even consider any of the supposed performance gains when making the purchase, just the extended plug life.
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
