snow plow for 88 2WD Toyota pickup
I am looking for a snow plow for a 1988 Toyota 2WD pickup. I found a company that has them for 1989-1995 2WD Toyota pickups. I thought the frames were the same for 1988 and 1989 models. Can someone explain if there really is a difference?
thanks
thanks
My 2wd Nissan doesnt move in the snow, My 2wd Isuzu did great cause it was an underpowered POS so it could hardly spin. My dads FS Chevy 2wd is bad in the snow too
my p/u doesn't like snow in 2wd. If i park along the street with the right tire in the patch they dont plow i cant backup without putting in in 4. I also cant back into my driveway (slight uphill) in 2wd. I personally wouldn't even bother. If you need a plow truck look by the sides of the road this spring, and im sure you can find a beat up f-150, or silverado with a plow for $1500 or less.
or you could just sell ur truck and buy this
http://cgi.ebay.com/ebaymotors/Toyot...spagenameZWDVW
The plow mount on my 89' 4x4 attaches to the frame rails at the tow hook bolts and the hole behind them. I don't think there is a difference there between the years or 2x to 4x. Its going to be pretty low though.
I don't know how a Toyota 2wd does in snow, but each vehicle I've ever driven has been different. My wifes BroncoII won't move an inch in 2wd but is one of the best in 4wd. My old '90 Dodge ram goes like a snowshoe rabbit & it's only a 2wd, granted it's heavy & it has a sure grip rear end & really aggressive tires.
I think if you have a good set of tires or chains & weight in the back on top of a locker it'll probably work; a 4wd would be better though.
bigblue82
10
07-06-2015 08:27 AM
