knock sensor problems searched and cant find
Old Mar 14, 2007 | 05:40 PM
dc'stoy's Avatar
I bought a JDM 3.0 to put in my 89' toyota and there has been some wiring issues that i thought i could get past by splicing the wires together to make the plugs match until i got to the knock sensor plug. The wire coming out of the harness on my 89' where it plugs into the knock sensor pigtail is a single, big wire and the knock sensor plug on the JDM which is probably a lot newer motor has two small wires running to it and I have read on here where it seems to be a PITA to change the knock sensors around. So is there anything that I can do to get around changing the sensors? is there a plug adapter or somethin. Both engines are on the ground so it wouldn't be as bad as if it were in the truck, but all the changes I am having to make to this motor to make it work in my truck is a PITA anyway so any help would be greatly appreciated.
Old Mar 15, 2007 | 01:19 AM
Jackie's Avatar
It?s really hard to find solution with that. What I did was just replace them with this Knock Sensors my friend recommended and had the problem fixed in no time. You could wait for other replies because I'm not sure if your situation was really same as what I had.
bigjstang
Jun 2, 2025 03:56 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
