3VZE Rebuild Questions
Old Mar 15, 2007 | 06:52 AM
justinking060310's Avatar
couple quick ones that i hope will be useful to others in the future:
(searching didnt turn up answers for me, but if you find one - a link certainly works)
1. Can anyone tell me the stock cylinder bore offhand?
2. Can Rod Bolts be reused on reassembly?
3. How does one go about purchasing plastigage(is there anything specific about it?
4. assembly lube suggestions?
5. Aside from boring hot tanking, and possibly decking what else might i need the machine shop to do with the block?
Thanks
Old Mar 15, 2007 | 05:11 PM
No one?
Old Mar 15, 2007 | 05:40 PM
Brenjen's Avatar
Get a chiltons or a haynes manual for the cylinder bore,
plasti-gauges can be purchased at an auto parts store,
rod bolts can be re-used,
assembly lube is a matter of personal preference,
bore & hone the block if needed. (honing is needed no matter what, but you get the idea)
Old Mar 15, 2007 | 05:46 PM
right on -- Thanks for the response
Old Mar 15, 2007 | 06:04 PM
toyota_mdt_tech's Avatar
Thanks
Bore specs are:
Standard diameter:
STD
Mark ?1?
87.500 ? 87.510 mm (3.4449 ? 3.4453 in.)
Mark ?2?
87.510?87.520 mm (3.4453?3.4457 in.)
Mark ?3?
87.520?87.530 mm (3.4457?3.4461 in.)
Maximum diameter:
STD
87.73 mm (3.4539 in.)
O/S 0.50
88.23 mm (3.4736 in.)
Plastic gauge comes in several sizes, you will need the .001-.003 and it should be green in color. Rob bolts, yes, you can easily reuse them. Assembly lube, use a thin film of nice assembly lube. As for cylinders, oil, but an old timer told me to use Crisco (the white shortening) and have used it with great results.
Old Mar 15, 2007 | 06:36 PM
wonderful info, thank you TECH - I read that page in the FSM shortly after my last reply -- thank you for the info
bigjstang
Jun 2, 2025 03:56 PM
coleypull15
Nov 3, 2015 07:41 AM
clok
Aug 1, 2015 09:42 PM
88yodabasket
Jul 13, 2015 01:32 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
