Gasket Maker on Valve Cover?
Old Jun 7, 2015 | 08:34 AM
Iceman4193's Avatar
Hey guys, I am replacing the valve cover gasket (The two semi circle pieces where leaking bad) and I am wondering if I should but some gasket maker to help seal a little better.
The stuff I have is Permatex silver high temp maker.
Old Jun 7, 2015 | 08:59 AM
Odin's Avatar
The top two recommended sealants on the 1/2 moons are Toyota FIPG and Permatex Ultra GREY.
Old Jun 7, 2015 | 09:00 AM
RustBucket's Avatar
I usually put a bit of permatex on the circular section of the moon washer and at the corners. I think the FSM only says to put it on the corners though.
Old Jun 7, 2015 | 09:06 AM
Iceman4193's Avatar
Ok so put the ultra grey along the edges of the half moon pieces and at the corners?
Old Jun 7, 2015 | 09:56 AM
rworegon's Avatar
Yes. ^^^
Old Jun 7, 2015 | 10:25 AM
Iceman4193's Avatar
Thank ya kindly
Old Jun 28, 2015 | 04:21 PM
Odin's Avatar
Actually you're doing it by the book. The FSM does indeed say to put sealant on the round portion of the end gasket (1/2 moon) and to the top corners of both gaskets where the valve cover makes contact.
Look at this link http://personal.utulsa.edu/~nathan-b.../7cylinder.pdf
Scroll down to page EG1–35 and have a look at Fig 7. and also Fig 8. on page EG1–36.
Right under that is the torque specifications for the valve cover.
Old Jun 29, 2015 | 10:01 AM
boxer.fan's Avatar
Don't think I but would hurt. I have done it and no leaks.
Old Jun 29, 2015 | 10:23 AM
boxer.fan's Avatar
Old Jun 29, 2015 | 03:47 PM
Odin's Avatar
Time will tell if it's ok or not.
I don't know what was in mine when I changed them but the installer did not use any sealant and they were leaking. I can tell you that the plugs I took out were smaller than the FelPro's I installed.
From what another member said the FelPro 1/2 moon plugs are thicker than the OEM plugs.
Based on that I would guess if you do not use sealant the FelPro's stand a better chance of not leaking Vs. the OEM plugs without sealant.
cars-guy
Aug 16, 2020 06:59 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
87blyota
Jul 10, 2015 04:31 AM
